TF CD32 Riser Revision 2 Build Guide.
TF CD32 Riser
arkadiusz.makarenko
Re: TF CD32 Riser Revision 2 Build Guide.
Post by arkadiusz.makarenko »
I have ordered few problematic devices and I will do my best to answer why they don't work over week or so.
It may be silly bug which stops enumeration some devices. Surpassingly cheaper devices work better for some reason.
~ Stanislaw Lem
alenppc
Post by alenppc »
I tried an ancient IBM MO32UO USB mouse and this one has the same issues as the Rapoo (phantom clicks and occasional random jumps). Just to exclude that I messed something up while building it, I built a second riser and I get the same behaviour on both. Unless I screwed up both of them...
All the logitech mice I mentioned above are of the same type, with a little bluetooth dongle so I suspect they probably use the same protocol.
EDIT: it looks like this depends on which accelerator you have plugged into the riser. All of what I reported happens when the TF330 is plugged in. When I tried it with the TF328, the phantom clicks and jumps were gone BUT the mouse will only move vertically and not horizontally.
arkadiusz.makarenko
alenppc wrote: Sun Feb 21, 2021 7:50 pm I tried an ancient IBM MO32UO USB mouse and this one has the same issues as the Rapoo (phantom clicks and occasional random jumps). Just to exclude that I messed something up while building it, I built a second riser and I get the same behaviour on both. Unless I screwed up both of them...
EDIT: it looks like this depends on which accelerator you have plugged into the riser. All of what I reported happens with the TF330 is plugged in. When I tried it with the TF328, the phantom clicks and jumps were gone BUT the mouse will only move vertically and not horizontally.
I have digged out Logitech Canada210 ,and movements work ok, but clicks are not decoded. I will have a look why this happens.
~ Stanislaw Lem
alenppc
Post by alenppc »
The same behaviour that occurs with TF328 occurs also when there is no accelerator plugged in. I am going to try it with the TF360.
alenppc
Post by alenppc »
This is so wild. On the TF360 there are no phantom clicks and jumps. Let me know if you need a TF330 for testing, I can send you one. I don't have any more 328s though.
Pretty sure Arek has a TF330... if not i'll get him one asap.
arkadiusz.makarenko
I have TF330, and all testing was done on it.
EDIT
I think it may be my optimizations. I did optimized each possible cycle. I think I may release CPU tiny little bit too early and some CPUs glitch?
~ Stanislaw Lem
alenppc
Post by alenppc »
arkadiusz.makarenko wrote: Sun Feb 21, 2021 8:43 pm I have TF330, and all testing was done on it.
EDIT
If you can send me the fw before optimizations, I can try and report back.
arkadiusz.makarenko
alenppc wrote: Sun Feb 21, 2021 9:10 pm
EDIT
You can have a look at history here: (But I wouldn't know exactly what changes were affected)
https://github.com/arkadiuszmakarenko/T ... r_binaries
~ Stanislaw Lem
alenppc
Post by alenppc »
Thanks, will test and report back (probably tomorrow).
Return to “TF CD32 Riser”
