PLCC to DIP adaptor - TF536 on A600
- 8 Bit Dreams
- Moderator Team
Re: PLCC to DIP adaptor - TF536 on A600
what if You widen the holes so that pin strips are going deeper?
This will reduce hight to 1 -2mm
Thats not a bad idea, the problem is if you make the holes large enough for the pin strip to drop in further
then there probably won't be room between the pads for the traces.
I was going to switch to sockets just to make it easier to solder at an angle with a 3D printable support. As that's the easiest solution I can think of. Else the other option would be to have the TF socket over the top of the keyboard ribbon cable. But as they are fragile enough these days, I didn't want to interfere with it.
No suggestion is a bad one so all ideas welcome. When I get time I'll tweak the design a bit
Could anyone possibly provide me with the latest rev2 firmware pre a2000 fix?
Doesn't look like I have anything apart from the most recent few off of the GitHub anymore, and most of the links here are now dead.
Much appreciated
Much appreciated
Check your email.
BTW, the TF536 now runs on A500, A1000, A600, A2000 and Atari ST via various PCB adapters for each machine. This is gotta be the world's most versatile card ever, all we are missing is 68K Mac.
Try a few different 3.1 EPROMs? The A600 might be picky - I don't think it uses pullups on it's address lines?8 Bit Dreams wrote: Tue Sep 08, 2020 8:43 pm ...
rev.2 TF536 board has a problem on KS 3.1 - it doesn't boot - just hangs on black screen,
Excellent cheers. I'll give them a go.alenppc wrote: Fri Sep 11, 2020 2:12 am Check your email.
@alenppc You forgot the mention the CDTV.... and the fact that a relocator exists for that one is your fault in the first place!alenppc wrote: Fri Sep 11, 2020 2:12 am Check your email.
@Lemaru, what's the difference from my adapter apart from the form factor? None?
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
Just the form factor, to give it a bit better fit and mounting points to hold it to the motherboard.kludge wrote: Fri Sep 11, 2020 9:20 am @Lemaru, what's the difference from my adapter apart from the form factor? None?
Was going to speak to someone about sorting out by he bus arbitration through logic but after seeing your method is also the way used in the early Furia cards I didn't see the point in going that way.
Happy to send you the files if you like. My routing could probably be neater.
(I have credited you on the board too)
I was just curious what made some have success with my adapter and some not. I think @terriblefire had success in booting the card on his A600, but his PLCC CPU still got hot? I could be wrong.Lemaru wrote: Fri Sep 11, 2020 9:40 amJust the form factor, to give it a bit better fit and mounting points to hold it to the motherboard.kludge wrote: Fri Sep 11, 2020 9:20 am @Lemaru, what's the difference from my adapter apart from the form factor? None?
It would be fun to have a look at your files. At least out of curiosity
My lack of focus:
My lack of focus:
