Getting WFI Working on TF3xx with ESP Module
theq
Re: Drivers for ESP modules
Post by theq »
terriblefire wrote: Tue Mar 31, 2020 7:31 pm tried it in a TF330?
S
The one in the picture is connected to the TF330 via Dupont cables :)
ah cool. no socket populated on the 330?
theq
Post by theq »
I put a normal header on it since I haven’t gotten the ESP-01S working on it... yet!
Would prefer the 01S over the breakout board I’m testing now due to the pin compability.
Need to figure out why the firmware is incompatible.
Smyckers
Post by Smyckers »
Here's my 330 with AWeb running :)
Smyckers wrote: Tue Mar 31, 2020 10:50 pm Here's my 330 with AWeb running :)
Nice job sir. Wish i could get roadshow working.
Bingo....
got roadshow + classicwb going.
Screenshot 2020-03-31 at 23.40.26.png (976.67 KiB) Viewed 6620 times
I'll follow up with the instructions tomorrow.
8 Bit Dreams
Post by 8 Bit Dreams »
Excellent!!! 🤗
Simple AmigaDOS script to set everything up for you. You need to have installed roadshow (maybe also with roadshow demo?) and downloaded http://aminet.net/package/comm/net/cslip-sana2.lha into the same folder as the script... see the zip attached.
Caveat is that it wipes your current settings clean and uses 8.8.8.8 for DNS resolution. You can update that if needed.
; (C) 2020 Stephen J. Leary
echo "Removing old slip.device"
IF EXISTS DEVS:Networks/slip.device
	delete DEVS:Networks/slip.device
EndIf
echo "Installing slip.device"
lha -q x cslip-sana2.lha ram:
copy QUIET ram:slip/slip.device DEVS:Networks/
IF NOT EXISTS ENVARC:Sana2
	echo "Creating SANA2 Config folder"
	MAKEDIR ENVARC:Sana2
ENDIF
echo "Creating slip0.config"
echo >envarc:Sana2/slip0.config "# Auto generated file"
echo >>envarc:Sana2/slip0.config "serial.device 0 38400 192.168.240.2"
echo "Create network interface"
echo >devs:NetInterfaces/Slip "# $VER: SLIP 1.1 (1.4.2020)"
echo >>Devs:NetInterfaces/Slip "interface=Slip"
echo >>devs:NetInterfaces/Slip "device=slip.device"
echo >>devs:NetInterfaces/Slip "unit=0"
echo >>devs:NetInterfaces/Slip "address=192.168.240.2"
echo >>devs:NetInterfaces/Slip "netmask=255.255.255.0"
echo >>devs:NetInterfaces/Slip "requiresinitdelay=no"
echo "Create routes file"
echo >Devs:Internet/Routes default 192.168.240.1
echo "Create name_resolution file"
echo >Devs:Internet/name_resolution nameserver 8.8.8.8
literally unzip the zip file and type "Execute install_script" at a cli.
TF3xx_slip.zip
(43.92 KiB) Downloaded 352 times
!Message from: Moderator
@terriblefire, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
matt020
Post by matt020 »
What wifi device/hardware are you using on the TF330?
And what are you using at the other end (that the wifi device connects to), is it a linux box?
Cheers.
matt020 wrote: Wed Apr 01, 2020 3:49 pm What wifi device/hardware are you using on the TF330?
Cheers.
Its a simple ESP8266 module... it connects to my wifi directly. One of those...
The TF330 has the exact pinout for this modue.
You could use them back to back though from a PC if you dont have a wifi network but the whole point of this port is to give the CD32 wifi.
