TF536 on A2000
Re: TF536 on A2000
@matt020 have you tried the TF536 without the A2091 installed?
Re: TF536 on A2000
I didn't, I really felt that because I was having the same results as other people, removing the A2091 would'nt make any difference. In hindsight, I probably should have removed it..dalek wrote: Thu Jul 16, 2020 12:52 am @matt020 have you tried the TF536 without the A2091 installed?
Of the other people here who are having TF536 and A2000 problems, do you have any cards plugged into the Zorro slots??
Re: TF536 on A2000
I had all cards removed during my tests...
- 8 Bit Dreams
- Moderator Team
Re: TF536 on A2000
Maybe it's worth to recompile rev.1 FW we used to rev.2 pcbs and check does it work on A2k or not...
- Admin sponsor
Re: TF536 on A2000
Just flash the working rev1 firmware in the rev2. IDE will not work everything else is unchanged.
Maximilian
Re: TF536 on A2000
The A2000 has a lot of resistor packs near the 68000 socket, could it be a termination issue due to the pull ups on A24-A31?
- Admin sponsor
Re: TF536 on A2000
A24-A31 are entirely internal to the TF536.. so its not likely. Its more likely an issue with the clock phase control.Maximilian wrote: Thu Jul 16, 2020 3:28 pm The A2000 has a lot of resistor packs near the 68000 socket, could it be a termination issue due to the pull ups on A24-A31?
Re: TF536 on A2000
I flashed my board back to the rev1 firmware.
Same behavior as before with the 3.1 rom, flashing bars followed by a black screen.
DiagROM 1.2 doesn't get as far as before, hanging during the fastmem check. I did try to plug in a mouse to to cancel fastmem detection, but with a mouse connected DiagROM only sends <> to the serial port, and hangs showing a blue screen.
Re: TF536 on A2000
I forgot to mention in my previous post that I have a 24 MHz 8 channel logic analyzer (a cheapo china one) on my bench, and would be happy to do any signal captures on my rev6 board that might help identify the issue...
- GadgetUK164
Re: TF536 on A2000
Is it possible the SMD component sizes fitted by the PCB manufacturer are the wrong size or something (on the underside). eg. resistor arrays, resistors.
