TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
Aeberbach
Re: TF1230 Beta Interest (Open Source)
Post by Aeberbach »
Well I wasn't careful enough when clicking the order button on Mouser... received 100 0201-sized capacitors. I can barely even see them. I have a few but not enough the right size. Why, when I search for 0603 do they show me 0201? I know metric/inch are confusing here but annoying to learn the lesson this way.
Any reason not to just 1uF 25V caps in their place? They all appear to be for decoupling.
Aeberbach wrote: Thu Sep 23, 2021 6:09 am Well I wasn't careful enough when clicking the order button on Mouser... received 100 0201-sized capacitors. I can barely even see them. I have a few but not enough the right size. Why, when I search for 0603 do they show me 0201? I know metric/inch are confusing here but annoying to learn the lesson this way.
A MLCC 1uF will do the same job really. Yeah.
chucky
Post by chucky »
0201.. hehe do not sneeze.. :)
markus0321
Post by markus0321 »
You have to solder while holding your breath :-)
And you have to drink a lot before soldering so that your hands do not shake ;-)
ICRY
Post by ICRY »
Hello all just checking that this puppy just needs the usual 5v & approx 20 milliamps of juice to programme outside, like the other TF cards.
Just checking before I let out the magic smoke :lol:
Many thanks.
Aeberbach
Post by Aeberbach »
Looking at 0201 I’m scared of even inhaling.
sporniket
Post by sporniket »
markus0321 wrote: Fri Sep 24, 2021 7:07 pm You have to solder while holding your breath :-)
Aeberbach wrote: Fri Sep 24, 2021 11:46 pm Looking at 0201 I’m scared of even inhaling.
It's time to use those surgery masks that we had to pilestock those recent years... :D
Aeberbach
Post by Aeberbach »
Just finished it and no time for a proper memory test yet but RC1 firmware flashed and it fired right up. I’m really liking this design. The enable 030 jumper looks perfect for running a switch to disable when things really don’t work with a faster CPU.
(And my capacitors were 0805; slightly harder to solder on 0603 pads but it worked.)
Aeberbach wrote: Sat Sep 25, 2021 11:17 am Just finished it and no time for a proper memory test yet but RC1 firmware flashed and it fired right up. I’m really liking this design. The enable 030 jumper looks perfect for running a switch to disable when things really don’t work with a faster CPU.
Strongly recommend choosing the assembly option to people. They'll do all that birdseed for you. Saves hours.
Danoo
Post by Danoo »
Good to hear you have it up and running :)
Just put together a custom 31 ROM with the eide.device included. Now the IDEs on the TF1230 & 1260 work straight-up no other boot device required. Not a difficult process, and there are number of tutorials available.
I did notice the 1260 boots quite a bit faster than the 1230 using the latest eide.device.
Life is really simple, but we insist on making it complicated - Confucius
Return to “TF330”
