TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
Re: TF CD32 Riser Revision 2 Design Complete
A simple implementation of WriteData() that does exactly the same thing you do but faster is..
void WriteData(uint8_t data)
                 uint32_t pupdr = GPIOB->PUPDR;
		GPIOB->PUPDR = pupdr & 0xFFFF0000; // no pull on bits 0 to 7;
		GPIOB->OTYPER |= 0xFF; // set to open drain - can this be done once?
		GPIOB->MODER = (GPIOB->MODER & 0xFFFF0000) | 0x5555; // set to output
		GPIOB->ODR = (GPIOB->ODR & 0xFF00) | data;
		// Maybe flash ack here?
		GPIOB->OTYPER &= ~(0xFF); // reset to non-open drain (why?)
		GPIOB->MODER = (GPIOB->MODER & 0xFFFF0000); // set to input
		GPIOB->PUPDR = pupdr; // restore
		// do this inline to avoid function call overhead
		GPIOC->BSRR = GPIO_PIN_11 << 16; // set
		GPIOC->BSRR = GPIO_PIN_11; // reset
I would setup all other settings ahead of time. I havent checked if all the masks will work but it should be close.
Also you shouldnt need to change the state of the pull ups between read and write. so that could maybe go away too.
I would honestly avoid using the HAL as its dog slow and its not really all that hard to write the routines you want.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
@terriblefire
I changed as you suggested
Only places of setting up push/pull and open drain, as it should be pushpull for placing data on the bus, and releasing it later to open drain.
(need to check if this is even required for changes between input/output)
plus
uint8_t ReadData() {
	uint8_t data = 0;
	data = GPIOB->IDR;
	return data;
and
I did try to place ack after comment
but Amiga was not booting.
It is already is snappier and I think Amiga boots faster.
I will have a look at enable/disable override when only required.
~ Stanislaw Lem
arkadiusz.makarenko
I fixed port clash in case when keyboard+mouse combo + gamepad is used... dirty fix but it works.
~ Stanislaw Lem
Excellent. I can look at other optimisations for you. Did you optimize the address read?
Also set readdata and writedata as inline
e.g.
inline uint8_t ReadData() {
	uint8_t data = 0;
	data = GPIOB->IDR;
	return data;
Then you can remove the code in the interrupt handler...
HAL_GPIO_WritePin(INTSIG7_GPIO_Port, INTSIG7_Pin, GPIO_PIN_SET);
	HAL_GPIO_WritePin(INTSIG7_GPIO_Port, INTSIG7_Pin, GPIO_PIN_RESET);
Every function call will eat several ARM cycles pushing and popping state from the stack.
Finally.. .when the new board arrives you can set A3 out on SPI_MISO and then you can get the whole address bus (A0-A5) (albeit with the bits out of order) from port C.
Screenshot 2020-10-28 at 20.17.40.png (78.45 KiB) Viewed 3875 times
EDIT: Ah A4 is on port A. Bummer.. still 2 reads isnt bad.
arkadiusz.makarenko
Yes, I replaced Read function to just using GPIOB->IDR directly, and replaced HAL calls to intsig7 to
	GPIOC->BSRR = GPIO_PIN_11 << 16; // set //HAL_GPIO_WritePin(INTSIG7_GPIO_Port, INTSIG7_Pin, GPIO_PIN_SET);
	GPIOC->BSRR = GPIO_PIN_11; // reset //HAL_GPIO_WritePin(INTSIG7_GPIO_Port, INTSIG7_Pin, GPIO_PIN_RESET);
Plus implemented crude enable/disable.
If any HID device is attached (except keyboard only) override is applied on ports.
I could do it more gradually, but would still need to take joystick buttons 2,3 on mouse override. Buttons are rarely used, but still cannot easily be done as I wanted initially. I would say good enough for now.
EDIT
I still have address reads to do.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Oct 28, 2020 8:31 pm
EDIT
Sweet. I think so long as you are not doing the full GPIO init inside the interrupt handler you'll see a massive speed up. You're probably also running code compiled for debug. Switching to release + optimized may give further gains.
arkadiusz.makarenko
terriblefire wrote: Wed Oct 28, 2020 8:53 pm
EDIT
Yes I have as it is convenient just now. I have created profile for compiling with -Ofast flag, will properly test it when I will have all basics done.
~ Stanislaw Lem
arkadiusz.makarenko
Now both ReadData and WriteData are static inline functions.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Oct 28, 2020 9:18 pm Now both ReadData and WriteData are static inline functions.
Sweet. You should be down to roughly 300ns for the transfer now.
arkadiusz.makarenko
Address reads are directly on registers as well. I don't think it is massive gain, but every little helps.
static inline uint8_t ReadAddress() {
	uint8_t address = 0;
	address = ((GPIOC->IDR >> 9) & 1U); //PC9 - INTSIG5
	address = (address << 1) | ((GPIOA->IDR >> 10) & 1U); //PA10 - A4
	address = (address << 1) | ((GPIOA->IDR >> 15) & 1U);//PA15 - INTSIG3
	address = (address << 1) | ((GPIOC->IDR >> 7) & 1U); //PC7 - A2
	address = (address << 1) | ((GPIOC->IDR >> 6) & 1U); //PC6 - A1
	address = (address << 1) | ((GPIOC->IDR >> 4) & 1U); //PC4 - A0
	return address;
~ Stanislaw Lem
Return to “TF CD32 Riser”
