It went in well. Nothing bent.
The Cosmic Puppet's Universe.
- Cosmic Puppet
Re: IMP DMA.
- Cosmic Puppet
Re: IMP DMA.
Everything works. Screen still the same. Any ideas what's happening?
Re: IMP DMA.
I would really take out the ossc and try something with simple RGB or VGA monitor if using high res .Cosmic Puppet wrote: Thu Jun 23, 2022 2:16 am Everything works. Screen still the same. Any ideas what's happening?
- Cosmic Puppet
Re: IMP DMA.
You're not gonna believe this @exxos but the colour 'noise' just stopped. I call it noise because you can see horizontal bands moving.exxos wrote: Thu Jun 23, 2022 2:19 amI would really take out the ossc and try something with simple RGB or VGA monitor if using high res .Cosmic Puppet wrote: Thu Jun 23, 2022 2:16 am Everything works. Screen still the same. Any ideas what's happening?
Anyway I had it set to white desktop on EmuTOS because that's always hidden my poor output, so then I switched back to stock TOS 1.04 and the colour has vanished!
P.S. In real life (whatever that is) it's completely monochrome. The photo gives a hint of colour for some reason.
Re: IMP DMA.
So the odd colour thing only happens in emutos ? That's crazy.Cosmic Puppet wrote: Thu Jun 23, 2022 2:36 am Anyway I had it set to white desktop on EmuTOS because that's always hidden my poor output, so then I awitched back to stock TOS 1.04 and the colour has vanished!
- Cosmic Puppet
Re: The Cosmic Puppet's Universe.
Seems a bit sus to me that shortly after changing the chip the problem goes away.
The DMA works too in that I can now have my printer switched on when I boot up the machine without it going ape.
What did you mean when you said the IMP DMAs sometimes cause trouble? How does this manifest itself @exxos?
Anyway I shall keep my Atari under observation and will definitely leave well alone if it continues being awesome!
Thanks guys!
Thanks guys!
I think you should switch back to emutos and try that again as it seems you changed 2 things at once.
The DMA doesn't have any connection the the video. Aside from the data bus. But if that was corrupted your machine wouldn't boot.
DMA issues cause problems with the floppy and hard drive. It doesn't do anything else. IMP chips cause a lot more noise on the system than other brands. Its why Atari mentioned at some point that a system should only have 1 IMP chip otherwise the system goes nuts. Fixes were done by placing a diode in its power rail to make it behave better.
In anycase, I don't see how the DMA can cause problems with RGB output. If that was true, the IMP DMA would he worse.
- Cosmic Puppet
Re: IMP DMA.
No, i meant having my white screen (available in EmuTOS) hides my NTSC output crappyness, so switched to TOS 1.04 to show the faults clearer and the colour had disappeared. So in 20 mins of running the computer since the new chip, it's cured! Will check again tomorrow (technically it is tomorrow) when I wake up.exxos wrote: Thu Jun 23, 2022 2:47 amSo the odd colour thing only happens in emutos ? That's crazy.Cosmic Puppet wrote: Thu Jun 23, 2022 2:36 am Anyway I had it set to white desktop on EmuTOS because that's always hidden my poor output, so then I awitched back to stock TOS 1.04 and the colour has vanished!
- Cosmic Puppet
Okay.exxos wrote: Thu Jun 23, 2022 2:58 am I think you should switch back to emutos and try that again as it seems you changed 2 things at once.
My last atari had 3 IMPs The MMU, the other square one and the DMA and it was awesome for over a decade.
Re: IMP DMA.
Why NTSC ?Cosmic Puppet wrote: Thu Jun 23, 2022 3:00 am No, i meant having my white screen (available in EmuTOS) hides my NTSC output crappyness, so switched to TOS 1.04 to show the faults clearer and the colour had disappeared. So in 20 mins of running the computer since the new chip, it's cured! Will check again tomorrow (technically it is tomorrow) when I wake up.![]()
I think you likely have a bad connection somewhere. Maybe manhandling the machine changing the DMA "fixed it" ?
