Archie A3000 inbound
HigashiJun
Re: Archie A3000 inbound
Post by HigashiJun »
Ok, so just 4 axial caps are still missing but I should receive them next week.
And a lot of used solder braid to throw away after my de-soldering session:
8-)
HigashiJun wrote: Sat May 23, 2026 10:05 am
8-)
Better get an order in :)
HigashiJun
rubber_jonnie wrote: Sat May 23, 2026 10:40 am Better get an order in :)
Definitely !
HigashiJun
All soldering finished !
Smoke test tomorrow if time allows.
HigashiJun wrote: Thu May 28, 2026 8:55 am All soldering finished !
Quite the soldering project, good stuff, let us all know how the smoke test goes :)
HigashiJun
rubber_jonnie wrote: Thu May 28, 2026 9:05 am Quite the soldering project, good stuff, let us all know how the smoke test goes :)
Yup, and I will be really fed up with (de-)soldering for quite a while now...
I will let you know for the smoke test for sure.
HigashiJun wrote: Thu May 28, 2026 10:08 am
Yeah, the de-soldering is a huge project all on it's own!
Yay! I'm sure that the magic will stay in the chips... Though probably best remove the expensive ones first before first power on.
HigashiJun
stephen_usher wrote: Thu May 28, 2026 8:13 pm Yay! I'm sure that the magic will stay in the chips...
:crossed1:
stephen_usher wrote: Thu May 28, 2026 8:13 pm Though probably best remove the expensive ones first before first power on.
Definitely good advice. I usually start with only passives installed and slowly build up to adding the more expensive IC's.
