ST536 STE EDITION
Re: ST536 STE EDITION
using Current3 I've had no issues so far.
I was going to leave frontier running for a few hours
coonsgm
Post by coonsgm »
I can't wait to update mine! (Hopefully tonight I have time)
PhilC wrote: Thu May 08, 2025 12:02 pm using Current3 I've had no issues so far.
:thumbup:
coonsgm wrote: Thu May 08, 2025 12:49 pm I can't wait to update mine! (Hopefully tonight I have time)
Slow and steady wins the race ;)
I need to change the PLD on the next revision board now.. Then do all the testing all over again :roll:
Frontbench has been running for 4+ hours now 8-)
I've just changed the PLD on the revised PCB.. next to find a PGA socket... And finish the build. These ones have the winbond SDRAM on...so I hope that will also behave now..
At some point I need to sort out the fastrom program. I wrote the verilog code in another firmware branch..but not tested yet.. always so much to do....
..and as I spent 10 minutes trying to get rid of the "short" between 2 pins.. Feking flood fill !! Thats getting removed there next revision as well!!
New board powered up :) Clock still look a bit crappy. But scope probing isn't idea. I've got x2 33R in series on the clock So likely need a bit more I suppose...
Does anyone else get this window behaviour with EMUTOS ?
For example, if you have a small window open over a large one, all the control buttons disappear from the background window ? I thought the desktop wasn't rendering properly at first for some reason but maybe this is supposed to be EMUTOS default behaviour ? :shrug:
DoG
Post by DoG »
Is it the same side by side. Active vs inactive?
DoG wrote: Fri May 09, 2025 9:58 am Is it the same side by side. Active vs inactive?
Yep.
