TF1260 stuff
SPiFF
Re: TF1260 stuff
Post by SPiFF »
Aeberbach wrote: Mon Aug 09, 2021 11:53 pm If you need a heatsink - Element14 stock number 1373294. Perfect fit on 060, 10mm high, self-adhesive.
Won't clear the keyboard, at least not on a TF1260.
Cheshire Noir
Re: TF1260 stuff
Post by Cheshire Noir »
Has anyone tried using copper tape to connect between the '060 and the base of the keyboard? Use the keyboard itself as a giant heatsink?
Alternatively, if copper tape isn't thermally conductive enough, how about some heatpipes? They're available from AliExpress for not many $$$.
Chesh
Re: TF1260 stuff
There is proper carbon thermal sheet, I think Samsung make it. Its 4x more conductive than copper.
idc
Re: TF1260 stuff
Post by idc »
It does fit perfectly, but not in an A1200 desktop case.
The underside of keyboard would foul on the heatsink. It is, as they say, a bit tight. :)
Aeberbach
Re: TF1260 stuff
Post by Aeberbach »
Sure, you need to modify it in a tight spot. I have used a file to angle one down (like the pictures of the Warp 1260 show), then sprayed it again with some stove matt black. Making a jig to hold it securely and then to apply a belt sander would make a nicer, flatter job. Obviously this is before you attach it :D
Higgy
Re: TF1260 stuff
Post by Higgy »
I made some slip-on keyboard risers (sorry pics are from A500 version). You can't raise the A1200 keyboard much before the case won't close.
It just changes the angle slightly to gain a bit more clearance to the CPU.
I think I need to ZIP the .STL as it won't let me attach it.
@Cheshire Noir this was discussed some time ago, with one idea being a soft conductive foam pad. To use keyboard plate as heat sink.
Feeling how cool a Rev 6 runs I have just heatsinked the CPLDs and a fan seems to work well moving the hot air away from where it is being generated (right to left).
I did not bother running my AMIGA a few weeks or so ago when we had that high 20oC heat.
Re: TF1260 stuff
Higgy wrote: Wed Aug 11, 2021 8:56 am I think I need to ZIP the .STL as it won't let me attach it.
Yes zip. Also we have a STL section here https://www.exxosforum.co.uk/forum/viewforum.php?f=62
squareeyes
Re: TF1260 stuff
Post by squareeyes »
Yep, I totally get it and agree.
lilwashu
Re: TF1260 stuff
Post by lilwashu »
Spotted one on eBay for the first time this morning:
https://www.ebay.co.uk/itm/Commodore-Am ... 3556391313?
Re: TF1260 stuff
The daft bit is we know exactly who this is just by looking at the card :)
Return to “TF360”
