:yay2: :dualthumbup: :cheer:
HigashiJun
Post by HigashiJun »
:girldance:
rubber_jonnie wrote: Thu Nov 09, 2023 2:49 pm
alexh wrote: Thu Nov 09, 2023 2:43 pm My A5000 is still non functional
Oh no, what'a wrong with it, I can't recall?
Same as yours battery leak.
https://stardot.org.uk/forums/viewtopic.php?t=22332
(Unfortunately the photos have now been deleted it was so long ago)
alexh wrote: Fri Nov 10, 2023 9:37 am
Ahh yes, I remember now. Do you think you'll have a go at fixing? Took me a fair while to do mine, and it still has damaged traces under an unpopulated socket. It's for the co processor IIRC and since they are vey expensive and not used that often, I opted to fit a socket over the top and ignore it. It's only soldered at the corners though, so a repair is still feasible.
I want to because it is an Alpha.
I have left it a very long time and have probably now forgotten how to re-assemble the case / screws :-)
alexh wrote: Fri Nov 10, 2023 11:59 am I want to because it is an Alpha.
How can you tell if it's an Alpha?
The serial number of the case + serial number of the board + 33MHz crystal instead of a 25MHz one
alexh wrote: Fri Nov 10, 2023 3:37 pm The serial number of the case + serial number of the board + 33MHz crystal instead of a 25MHz one
I'll have a look at mine next time I have it open, which may be soon as I am considering adding another 1GB drive image to my BlueSCSI and want to back up the card I have in there at the moment.
Wow. Riscos is a weird OS IMHO.
Trying to get anything working requires a degree in nuclear physics, and an encyclopaedic knowledge of the file system to find anything.
I might have got networking running, but wow I've yet to do anything but ping other machines, and even something as simple as FTP is fighting me.
Grrrrrrr.
:pullhair: :pullhair: :pullhair:
You need a program called LANman98
https://www.riscosdev.com/lanman98/
https://web.archive.org/web/20170201060 ... rking.html
If you're brave you could talk to Jake Hamby about his newer version which supports smb2
https://github.com/jhamby/RiscOS-OmniLa ... hamby_smb2
