TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
supaduper
Re: TF1230 Beta Interest (Open Source)
Post by supaduper »
kulamario wrote: Tue Sep 14, 2021 2:00 pm Twice time amiga frozen in EBM
Just tested ESM here and it works fine on my 1d4 setup
alenppc
Post by alenppc »
supaduper wrote: Tue Sep 14, 2021 2:17 pm
Same here, this is usually the indication of a bad cpu that can't handle 50 mhz with burst.
alenppc
Post by alenppc »
The onboard TF IDE is working fine for me. 3mb/sec according to SysUselessInfo.
kulamario
Post by kulamario »
Later I'll check on 100% orginal cpu
alenppc wrote: Tue Sep 14, 2021 3:03 pm The onboard TF IDE is working fine for me. 3mb/sec according to SysUselessInfo.
Use ScsiSpeed from ...
http://aminet.net/disk/moni/DiskSpeed42.lha
Avinitlarge
Post by Avinitlarge »
My hdd isnt showing up at all when its connected to the TF :( . Ive got 2 TF's and its the same with both
GadgetUK164
Post by GadgetUK164 »
Avinitlarge wrote: Tue Sep 14, 2021 7:04 pm My hdd isnt showing up at all when its connected to the TF :( . Ive got 2 TF's and its the same with both
Did you install the EHIDE driver? It uses the same one as the TF1260 I think!
Avinitlarge
GadgetUK164 wrote: Tue Sep 14, 2021 7:06 pm
Ah, No i didn't
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Tue Sep 14, 2021 12:46 pm
arkadiusz.makarenko wrote: Tue Sep 14, 2021 12:09 pm
Ok. So what happens it simply doesn't reset correctly, but after manual keyboard reset it loads driver fine.
I managed to load SysInfo from external ide, and i got this
Ah then we might have a soft reboot issue like the TF330r2
Ok so it works we just need to make it fast.
I poked software reset a little bit more, and it is consistent on my Amiga.
It affects both kickstarts, and non of software reset applications work with my TF1230.
I disconnected TF1230, and it did work again on vanilla amiga.
So far it looks like only I am affected by this issue?
~ Stanislaw Lem
alenppc
Post by alenppc »
arkadiusz.makarenko wrote: Tue Sep 14, 2021 8:27 pm
I can't reproduce this, it seems software reset works normally here.
Return to “TF330”
