Yeah i think a STM32 type setup would be great but as you say debugging would be difficult.arkadiusz.makarenko wrote: Sun Dec 24, 2023 10:34 amHmmm... This one?terriblefire wrote: Sat Dec 23, 2023 11:31 pm
I'll need to jury rig a keyboard later too. MIght need help from @arkadiusz.makarenko
Porting this to full USB shouldn't be too difficult.
https://github.com/Meaxy76/x68k-PS2converter
Testing and debugging might be more challenging.
A X68000 arrived
- Admin sponsor
Re: A X68000 arrived
- Admin sponsor
I think i might need 2 drives to boot? I tried this jumper setup but the thing just stops booting anything then
Wonder if my gotek needs updated or something
Sorry, I meant S1 on one and S0 on the other.
Definitely worth updating FlashFloppy on Gotek.
I think your now just hitting the SRAM not being configured. It's so integral to the X68K working (correctly).
Interesting, I had a feeling that I could not get Memtest to display on my 1942 and I had to use VGA screen as Memtest is at some high Res.
Regarding Mouse/Keyboard you guys don't need to create your own, this works well and is in a small form factor:
https://nfggames.com/forum2/index.php?P ... pic=7130.0
- arkadiusz.makarenko
- Moderator Team
Do you have jumpers across S0, S1 and JC?
Docs says this about jumper settings.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
But I get the same issue from SRAM wipe disk. So it must be a disk issue.Higgy wrote: Sun Dec 24, 2023 12:21 pm Sorry, I meant S1 on one and S0 on the other.
After its running just turn the 1942 off and on and it syncs happily. It doesnt initially.Interesting, I had a feeling that I could not get Memtest to display on my 1942 and I had to use VGA screen as Memtest is at some high Res.
I couldnt get that immediately and we have several projects that do USB support with STM32 like the TFMSX.. so i was thinking to just hack something quickly with what i have.Regarding Mouse/Keyboard you guys don't need to create your own, this works well and is in a small form factor:
I am looking at my Goteks with a clearer head.arkadiusz.makarenko wrote: Sun Dec 24, 2023 12:24 pm Do you have jumpers across S0, S1 and JC?
Drive 0 - S0 and JC
Drive 1 - S1
No cable twist between Drive 0 and Drive 1
- Admin sponsor
Had absolutely no joy with the Gotek's @Chrissy(?) sent me a couple of 5.25" disks to try so i'll give them a go later.
Also a 5 of the PCBs for this project turned up to today as replacements for my PSU.
https://github.com/leaded-solder/x68000-pro-picopsu
3 are going spare if anyone wants one. I can divide the cost of the PCB order by 5 and add shipping. Its roughly a £5 per PCB.
- Admin sponsor
So absolutely no joy. No floppy combination works.
Same symptoms as this thread.. https://nfggames.com/forum2/index.php?topic=6755.40
@terriblefire when you said:
And the other 2 disks (unsure of what they are as its just gotek numbers)
Are those from the archive I posted? And was the Memtest also from that archive?
Also you have tried actual 5 1/4 disks now?
You've had so something booting so that is a good sign. When I had major weirdness it was down to the SRAM. That configuration is really the life blood of the computer. On my Expert 2 it would load Human OS but then not Masterdisk and the text (dos style white on black screen) went 2x size!?!
I replaced the actual SRAM chips and it's been solid. I took it that it was powered on/tested with the Cap leaked PSU and it fried the SRAM. Maybe delicate chips like C64/Spectrums which can have RAM failure.
Anyway if you did got some of my Gotek images working, I will post some more up tomorrow (might be afternoon). As I could get somethings to boot even with fudged SRAM. Have you got the battery installed?
Don't go taking the PCB apart just yet, I am hoping it is just pesky SRAM gremlins
- Admin sponsor
I've tried all of the above. Real 5" disks, Goteks and HxCs. Only memtest68k boots. I'd bet that that other game that guy got working will work too. Nothing else boots. Master disks sulk so do games.Higgy wrote: Thu Dec 28, 2023 11:12 pm @terriblefire when you said:
Don't go taking the PCB apart just yet, I am hoping it is just pesky SRAM gremlins![]()
I removed both 5" disks and cleaned the heads. @Chrissy sent me a Master disk and it just gets spat out again.
