TF1260 Testing FW
supaduper
Re: TF1260 Testing FW
Post by supaduper »
matt020 wrote: Wed May 10, 2023 6:36 am Has anyone tried increasing the speed to greater than 50mhz?
Running a LC 060 @ 94mhz here and is rock solid used sysinfo with no problems and been running the electronicknights demo` hologon` for ages on loop without a hiccup, this is using the IDE on the TF1260
will try the A1200 ide later see if I get your symptoms
idc
Post by idc »
I have two full 68060 processors, a rev. 6 and a rev. 5, plus two 68LC060 rev. 4 (one is an RC66)… I’m happy to test functionality on all of these at various speeds later, although it’s a bit time consuming to keep swapping the CPUs over.
I think I should perhaps buy another card. :lol:
So one user, @indigolemon has been quietly testing this firmware for about 10 months for me. Overclocks nicely for him.
Aardvark82
Post by Aardvark82 »
matt020 wrote: Tue May 09, 2023 5:24 pm060 Rev5 is no longer stable at 66mhz, ironically it’s when reading from the HDD on the 1200 IDE port that causes the problems (random block errors when decompressing an LHA file for example, or block errors when loading SysInfo)
60mhz seems to be OK
Previously on the Xmas firmware, 66mhz was stable, even 75mhz on a very cold day for short periods of time
My rev6 is only stable at 50mhz and 100mhz with iteration 1. In 2021 Alpha, 60mhz-66mhz is also working.
Edit: 94mhz is stable too after rechecking.
supaduper wrote: Wed May 10, 2023 6:22 amHey Aardvark , there is a good chance it is your rom set that is causing you problems so you need to recompile onother set of 3.2.1 roms like I did
Good to know, I'll stick with this Rom for now in case it's useful for further testing, then maybe burn 3.2.2.
Aardvark82 wrote: Wed May 10, 2023 10:47 am My rev6 is only stable at 50mhz and 100mhz with iteration 1. In 2021 Alpha, 60mhz-66mhz is also working.
94 should also be stable?
supaduper
Post by supaduper »
terriblefire wrote: Wed May 10, 2023 10:51 am
Just trying my Rev 6 and yes it is stable at 94mhz and 100mhz, noice :)
Higgy
Post by Higgy »
I hopefully will get some time tonight to flash firmware and test Iteration 2 on a 3.1.4 custom with ehide.
I don't think anyone has reported with 3.1.4 yet?
Aardvark82
terriblefire wrote: Wed May 10, 2023 10:51 am94 should also be stable?
Sorry, 94 is stable too. Rechecked and the crash I had was software related.
Ok i'll try and figure out why we've lost 66Mhz over the next few days. On the mend from covid now.
OK i noticed one thing that might affect 67Mhz compared to the xmas 2021 firmware.
try this iteration 3.
tf1260r1_2023_05_10_6166388_alpha.zip
(152.89 KiB) Downloaded 89 times
Return to “TF360”
