Cheers
Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
Re: Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
Hi - I have had a batch made. Unfortunately there is a problem with the ACSI bus IDC pinout. I need to make up a test cable and test further, but at the moment I am working on trying to get PIStorm working with ATARI STs
. Once I'm happy with the outcome, I will post on here
Cheers
Cheers
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Are you using Pistorm-ST by BadWolf?dad664npc wrote: Thu Jan 05, 2023 12:41 pm at the moment I am working on trying to get PIStorm working with ATARI STs![]()
https://github.com/dh219/pistorm/tree/wip-pistormst
(Ah I just noticed you're CryptoDad over on the Discord server)
jfceklosky
Thanks for letting us know about the issue with the first batch board IDC connector issue.
When you have things worked out, I would be very willing to help test these out.
I have 2 MEGA ST's one with TOS 1.04 and the other with TOS 2.06/ICD Adspeed 16 installed. I have an STE on the way, but I am unsure about the status of this unit.
jfceklosky
I have a gerber for a DB 19 to IDC 20 if you need one. I modeled this after the one that have for an Ultra Satan device.
About Ultrasatan RTC if you need this feel free to use it.
This is for my ACSI to Teensy 4.1 hard drive implementation with MTP.
case 0x20: // UltraSatan's special commands (0x20).
// from https://github.com/atarijookie/ce-atari/blob/master/ultrasatan/UltraSatan/special.c
// Format of UltraSatan's special commands is as follows:
// cmd[0] - (ACSI ID << 5) | 0x1f - command in ICD format
// cmd[1] - 0x20 - group code 1 (1 + 10 bytes long command) and command TEST UNIT READY
// cmd[2..3] - the 'US' string (US as UltraSatan)
// cmd[4..7] - special command code / string
// cmd[8..10] - 3 bytes of parameters
// so the complete command could look like this:
// 0x1f, 0x20, 'USRdFW', 0x01, 0x0010 (ACSI device 0: read sector 0x0010 of firmware 1)
// All i need is RTC functionality implemented from UltraSatan's RTC clock tools (US_GETCL.PRG or US_SETCL.PRG).
// for exemple: Len 11 Command 1F 20 55 53 43 75 72 6E 74 46 57 -- ReadCurrentFirmwareName
if (cmdBuf[2] == 'U' && cmdBuf[3] == 'S') { // some UltraSatan's specific commands?
Serial.println(" ICD 0x1F UltraSatan's special commands (0x20)");
for (uint32_t i = 0; i < 512; i++) {
dataBuf[i] = 0; // clear the data buffer
// cmd [4.5.10]
if (cmdBuf[4] == 'C' && cmdBuf[5] == 'u' && cmdBuf[10] == 'W') { // read the name of currently running FW (VERSION STRING)
Serial.println(" read the name of currently running FW");
// cmd# 00 01 02 03 04 05 06 07 08 09 10 Len 11.
// HEX 1F 20 55 53 43 75 72 6E 74 46 57 // Special_ReadCurrentFirmwareName https://github.com/atarijookie/ce-atari/blob/master/ultrasatan/UltraSatan/scsi_icd.c
// ICD ** U S C u r n t F W
// Teensy STRING for the US_GETCL.PRG or US_SETCL.PRG
dataBuf[0] = 'T'; //
dataBuf[1] = 'e'; //
dataBuf[2] = 'e'; //
dataBuf[3] = 'n'; //
dataBuf[4] = 's'; //
dataBuf[5] = 'y'; //
dataBuf[6] = ' '; //
dataBuf[7] = '4'; //
dataBuf[8] = '.'; //
dataBuf[9] = '1'; //
dataBuf[10] = ' '; //
dataBuf[11] = 'A'; //
dataBuf[12] = 'C'; //
dataBuf[13] = 'S'; //
dataBuf[14] = 'I'; //
dataBuf[15] = ' '; //
dataBuf[16] = 'V'; //
dataBuf[17] = 'e'; //
dataBuf[18] = 'r'; //
dataBuf[19] = '.'; //
dataBuf[20] = '0'; //
dataBuf[21] = '.'; //
dataBuf[22] = '0'; //
dataBuf[23] = '1'; //
dataBuf[24] = 0x00; //
sendDma(512); // 512
commandSuccess();
} else if (cmdBuf[4] == 'R' && cmdBuf[5] == 'd' && cmdBuf[10] == 'C') { // read clock
Serial.print(" read clock ");
// Len 11 Command 1F 20 55 53 52 64 43 6C 52 54 43
// ICD U S R d C l R T C
digitalClockDisplay(); // Show on Serial
dataBuf[0] = 'R'; // RTC signature
dataBuf[1] = 'T';
dataBuf[2] = 'C';
// fill dataBuf with clock data
dataBuf[3] = (year() - 2000); // yea;
dataBuf[4] = month(); // mon;
dataBuf[5] = day(); // day;
dataBuf[6] = hour(); // hou;
dataBuf[7] = minute(); // min;
dataBuf[8] = second(); // sec;
sendDma(512); // send 512 bytes
commandSuccess();
} else if (cmdBuf[4] == 'W' && cmdBuf[5] == 'r' && cmdBuf[10] == 'C') { // SET, write clock
Serial.println(" write clock ");
// Len 11 Command 1F 20 55 53 57 72 43 6C 52 54 43
// ICD U S W r C l R T C
readDma(512); // read 512 bytes
commandSuccess();
Serial.print(' ');
Serial.write(dataBuf[0]); // RTC signature
Serial.write(dataBuf[1]);
Serial.write(dataBuf[2]);
Serial.print(' ');
for (uint32_t i = 3; i < 9; i++) {
Serial.print(dataBuf[i]); // data buffer
Serial.print(' ');
// This sets the system time lib. (NOT the Teensy RTC Clock)
// set your seperated date/time variables out as normal and update system time FIRST
//setTime(hour(), minute(), second(), day(), month(), year())
setTime(dataBuf[6], dataBuf[7], dataBuf[8], dataBuf[5], dataBuf[4], dataBuf[3]); // (hr,min,sec,day,mnth,yr) --- yr is 2 or 4 digit yr (2010 or 10 sets year to 2010)
// now lets set the RTC in teensy before exiting.
// now we can use the system time to update the Teensy's RTC bits
// This sets the Teensy RTC Clock from Arduino Time library(system time) - epoch stylee, just like it wants :)
Teensy3Clock.set(now());
// Len 11 Command 1F 20 55 53 52 64 53 74 0 0 0
// ICD U S R d S t null // read settings
} else {
sdc.lastErr = LASTERR_OPCODE; // Invalid Command (opcode not implemented)
commandError();
if (!cmpn(&cmdBuf[4], "RdFW", 4)) // firmware read?
Special_ReadFW();
return;
if (!cmpn(&cmdBuf[4], "WrFW", 4)) // firmware write?
Special_WriteFW();
return;
if (!cmpn(&cmdBuf[4], "RdSt", 4)) // read settings?
Special_ReadSettings();
return;
if (!cmpn(&cmdBuf[4], "WrSt", 4)) // write settings?
Special_WriteSettings();
return;
if (!cmpn(&cmdBuf[4], "RdCl", 4)) // read clock?
// Special_ReadRTC(); // todo
//return;
if (!cmpn(&cmdBuf[4], "WrCl", 4)) // write clock?
// Special_WriteRTC(); // todo
//return;
if (!cmpn(&cmdBuf[4], "CurntFW", 7)) // read the name of currently running FW?
// Special_ReadCurrentFirmwareName(); // todo
//return;
if (!cmpn(&cmdBuf[4], "RdINQRN", 7)) // read INQUIRY name?
Special_ReadInquiryName();
return;
if (!cmpn(&cmdBuf[4], "WrINQRN", 7)) // write INQUIRY name?
Special_WriteInquiryName();
return;
if (!cmpn(&cmdBuf[4], "RdLog", 5)) // read command log?
Special_ReadLog();
return;
} else {
commandError();
break;Re: Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
Not some great news... for the PCB design, I used an auto direction voltage level translator (TXB0108). This part has proven to be troublesome for me, in that I see random data (noise?) and very slow direction switching. This of course means the design does not work.
For the prototype, I used a 74LVC245 part. I moved away from this at some point as I was having unreliable IO and purchased a couple of Adafruit voltage level translators instead. This allowed me to develop the software and have a reliable interface.
In retrospect, I am guessing I was having software problems at the time as now, I have reverted back to this 245 part and it works reliably and is fast - seeing short transfer speeds of 2.5 MB/s and sustained transfer speeds of 980 KB/s when running PICO at 133 MHz.
This is the first time I have designed a PCB and it has been enjoyable and expensive. My first batch did not work at all as I had chosen the wrong chip footprint for the selected part. The second batch (the current batch), I have wired the IDC connector incorrectly but was able to continue testing with a modified cable.
At some point in the near future, I will try again - 3rd time lucky... watch this space...
jfceklosky
Thanks for the update. I will be keeping an on the project and will be willing to print out a board and test.
For the board will you be going with TH (through hole) components?
Been a while.
Busy getting PiStorm working on the ATARI.
Attempt three works YAY! Over the next few days, I will update GitHub.
nice project
http://260ste.atari.org
jfceklosky
Nice to see the progress. I am very interested in building one of these up!
I would also be willing to work on a TH design based on your original board.
