If you PM me your address I will pop some in the post to you.
Sinclair QL - wanted one since 1984
Re: Sinclair QL - wanted one since 1984
I think I saw somewhere that 3 pin fan sockets for CPUs and the like can be made to fit the QL power socket with a bit of persuasion. I've not tried this myself but it might be a quick way to see if the thing has life before working on a more permanent solution?PhilC wrote: Fri Jun 10, 2022 1:53 pm
I'm going to try and make a 3d printed plug to match the Power socket on the QL as well.
@Wrangler ill check that out, thank you.
@rubber_jonnie - have you tried using SMSQ/E yet with the Gold Card?
I must admit that I'm a traditionalist and not keen on the replacement OSs...
It just looks wrong without the "© Sinclair Research Ltd 1983" banner.
My original machine had JS ROMs from new and the rescued machine got JS ROMs fitted.
Not yet, no. It is somewhere on my massive list of 'Things to to when I no longer have any broken computers to fix'Icky wrote: Fri Jun 10, 2022 7:39 pm @rubber_jonnie - have you tried using SMSQ/E yet with the Gold Card?
The new power supply bits are arriving tomorrow morning, so hopefully I'll be able to make something up so that I can test it sometime tomorrow evening.
The QL has also had a bit of a spruce up but is still lacking its Caps Lock and CTRL keys. I've seen someone on eBay selling them but they want a fiver per key, so I may just have a go at designing and 3d printing some new ones in the short term.
Well that’s the parts arrived today, actually smaller than I thought they would be as well.
So the QL PSU ties both the 15VAC neutral and the 9VDC negative to the same pin.
Never done this before, is there anything I should fit? Caps and diodes on the DC side of things perhaps?
I’m off to do some Googling. Anyone here done this before in a power supply?
I'm sure I'm being silly with the whole PSU secondary voltage neutral going to DC ground, I mean FFS it's what it does in an AC/DC transformer, the only thing that's confused me is that I'm using an AC/AC transformer to get the 15VAC that the QL needs, then an SMPS 9VDC power supply fed from 230VAC to provide it with power.
I think I need a lie down
