... the same as before!
Xilinx programming cable USB -- anyone got this one?
- frank.lukas
Re: Xilinx programming cable USB -- anyone got this one?
That's a shame. I was hoping if it had now been programmed by Impact it could be used with xc3prog. Never mind, if you have a working setup, we can at least try things.
- frank.lukas
Someone over the Atari-home forum told me the driver is "xpc" but it not work correct with xc3sprog. Same can you read at the web.
Impact works fine ...
Hi Frank,
I believe your TT ram problem might only require re-flowing the solder on your ram chips and ram buffer chips.
I finished building a DFB1 today and it would not detect the ram even though I thought it was soldered perfectly. I put flux over and re-flowed and now it is all working.
Great to see another board firing on all cylinders, Steve!Steve wrote: Mon May 30, 2022 3:45 pm Hi Frank,
I'm starting to wonder if @frank.lukas's problem is indeed a solder joint or similar that's vibrated loose in shipping as there does seem to be a time (which to me impies heat) dependence to it.
It's all very odd.
Hopefully we'll get there.
