False alarm! Was: 68HC000 not perfectly 68000 compatible
Re: False alarm! Was: 68HC000 not perfectly 68000 compatible
There is no PRG version of closure. IIRC troed used his own loading routines so there are no files even on the disk.
HigashiJun
Post by HigashiJun »
Good to know that.
Will then have to go with .MSA...
troed
Re: 68HC000 not perfectly 68000 compatible (!)
Post by troed »
HigashiJun wrote: Wed Jan 05, 2022 7:28 am By the way, my Mega ST is NTSC, and I heard NTSC versions had some problems with Closure...
An NTSC Mega ST is likely 8.01MHz which should work fine with Closure v1.0. NTSC STEs are 8.05MHz and that didn't work in Closure 1.0, but does work with Closure 1.1.
https://sync.wtf
The same type of fullscreen lines as in Closure also exist in the pre-release of the "Expansion of the Universe" test program I've released. That's a .PRG. (It's meant for calibrating your screen/capture equipment for the largest possible ST screen possible to create)
https://sync.wtf/EXPANDED_BETA1.ZIP
keys: left shift, right shift, '1' and '2'.
/Troed
HigashiJun
Great !
Thank you for the links.
