Bikerbob's H5 C1 build
Bikerbob
Re: Bikerbob's H5 C1 build
Post by Bikerbob »
PhilC wrote: Sat Sep 11, 2021 6:00 pm @Bikerbob as long as you have everything else right and the rom ce line jumpered to right hand pin J13?
It is much more predictable to try and diagnose with a tos1.04 rom in the board thought as you're then only focusing on internal, not external equipment.
Yeah I will not do this till after it has been determined to work..
So.. I have a question.
after more reading.. it seems the cloudy needs to be used with the lightning or the storm.
Can my decoder and dual tos chip be used with any other board?? or its for the H5?
James
1088XEL, 800 incognito
Bikerbob
Post by Bikerbob »
Sorry.. one more question.
The sizing on the holes for the Floppy posts... were they made for a specific post?? not the original.. They seem very small.
I cannot get any post I have to fit in the holes?
James
Post by JezC »
Bikerbob wrote: Sat Sep 11, 2021 8:44 pm Sorry.. one more question.
James
I'd had the same problem on the H4 as well as the H5 but assumed there were different sizes of the posts & I was just 'unlucky' to have larger diameter posts... :shrug:
JezC wrote: Sat Sep 11, 2021 9:12 pm I'd had the same problem on the H4 as well as the H5 but assumed there were different sizes of the posts & I was just 'unlucky' to have larger diameter posts... :shrug:
Never gave it much thought .. Not sure if anyone actually tried the posts... What do they all measure compared to a original board ?
exxos wrote: Sat Sep 11, 2021 11:29 pm
The H5 holes are 6mm and the original on the three plastic post holes are 6.5mm.
The brass peg post fits perfectly but I sanded down the collar on the plastic ones for one build. You could use these https://www.thingiverse.com/thing:3219623 modify slightly and 3D print.
Finally I have gone down the route of these plastic M3 posts which you can build up nicely to get the right height. Plastic M3 peg set
Ahhh https://www.exxosforum.co.uk/forum/viewt ... =62&t=1356
Not H5 intended, but I forgot all about that project. I will do a new STL when I get my printer fixed.
Bikerbob
Post by Bikerbob »
ok we are working... so far only 2 weird things..
1. I cannot get Desktop info on either TOS. 1.4 will reset and 2.06 will kill the keyboard mouse click, and I cannot open anything.
2. The floppy drive is continually polling?? aka something is always happening.. is that what this supposed to happen?? IT works.. just I can always hear a tick tick tick ... from the drive.
James
Blitter jumpers installed ?
Bikerbob
Post by Bikerbob »
far as I can tell all jumpers installed correctly.
Bikerbob
Post by Bikerbob »
anyone have another suggestion?
I am using a 720k drive in the machine - even though I have the 1.44 gal. Can that cause the ticking?
I have not run a program yet.. or the diag cart.. I can .. not sure what to look for about the Desktop info not working.
James
Return to “H5 C1 USER BUILDS”
