Alienkid H5 C1 build
alienkidmj12
Re: Alienkid H5 C1 build
Post by alienkidmj12 »
ah yes, i seen that, what's it for again ?
alienkidmj12
Not far off now. Just need memory riser bits ;) as falcon memory module current hits psu.
exxos parts arrive :)...yay...Was expecting both mc68b50 chips to be the same :( exxos is killing my work of art ;) ha. A bit gutting. May try polishing one. But they are slightly different part nos.
Beauty :)
alienkidmj12
Midi ports added, 2 points on rear of board bridged.
Connected both centre buts beneath expansion port
Back in its home
New case top painted with less issues
Extra 12v lead connector ran from PSU for led strip
Still need a solution for standing ram up higher as still hitting psu, ordered a strip of these https://www.ebay.co.uk/itm/283290032728 ... 4155495048
What RAM card are you actually trying to fit ?
alienkidmj12
See up, the pcb is too close to psu pcb so needs lifting a bit
cheers
dave
Ah,. Mine (blue) misseses the PSU by a couple of mm. The black cat one is larger so it doesn't physically fit.
I would suggest you just get a simm socket as it looks like you're going down a world of pain otherwise..
alienkidmj12
owch......
alienkidmj12
exxos wrote: Mon Aug 23, 2021 7:58 pm Ah,. Mine (blue) misseses the PSU by a couple of mm. The black cat one is larger so it doesn't physically fit.
I'm assuming you need to have the board all the way onto the pins at the back, i managed to get it on, with about 5 mm of the pins left showing.
bit annoying really, can't even shave anything off the pcb :( as circuit is real near the edge
i've another falcon board but the sim is actually underneath, so that also wouldn't fit.
anyways, i get no video output yet, so i'm guessing its this.
regards
dave
alienkidmj12 wrote: Tue Aug 24, 2021 7:29 pm Im assuming you need to have the board all the way onto the pins at the back, i managed to get it on, with about 5 mm of the pins left showing.
Probably isn't contacting properly.
@alienkidmj12 one option if you need to raise the Falcon RAM board height is to use longer header pins.
I used them on my ALPHA board to clear the PSU. You can just see the board on the taller headers in the pic below.
Return to “H5 C1 USER BUILDS”
