FPU Compatible Software
General Discussion, STOS.
Re: FPU Compatible Software
pixelpusher wrote: Sun Jun 06, 2021 8:31 pm Thx! Let me know if I should upload the archive with LFED here (zip including sources + binary is only 68 kb) for testing...
If there is a simple thing to load so I can test GB6's patches... ?
pixelpusher
Post by pixelpusher »
exxos wrote: Mon Jun 07, 2021 1:19 pm
It's the LFED20.PRG in the zip (the original folder inside contains older stuff...).
LINE_F.zip
(56.4 KiB) Downloaded 136 times
Install it in the auto folder. On a MSTE or ST with SFP-004 it should pass your FPUTEST program, allow starting GB's float test - but then crash.
pixelpusher wrote: Mon Jun 07, 2021 3:29 pm Install it in the auto folder. On a MSTE or ST with SFP-004 it should pass your FPUTEST program, allow starting GB's float test - but then crash.
ah don't think I can test it then here as I can only really try it in steem. I don't have any FPU machines other than my Falcon.
pixelpusher
exxos wrote: Mon Jun 07, 2021 3:37 pm
You could manipulate the _FPU cookie on your Falcon and set it to 0x0001 in the high word and 0x0001 in the low word. GB then still should execute on the FPU via LineF ops.
pixelpusher wrote: Mon Jun 07, 2021 3:41 pm You could manipulate the _FPU cookie on your Falcon and set it to 0x0001 in the high word and 0x0001 in the low word. GB then still should execute on the FPU via LineF ops.
I have no idea how to do that.. and no room to plug my Falcon in either currently.. but here you can try it... would still need testing on a Falcon or something to make sure i've not broke stuff also..
GB609B33.zip
(56.91 KiB) Downloaded 176 times
pixelpusher
exxos wrote: Mon Jun 07, 2021 3:44 pm
GB609B33.zip
Starting the version prints out only an error message with
"File not found at line 21 in file E:\GB6\GUI33.BAS in modue BLOAD/BSAVE"
Is the zip content expected to be merged or is something missing? Does happen without LFED being installed too.
pixelpusher wrote: Mon Jun 07, 2021 5:17 pm Is the zip content expected to be merged or is something missing? Does happen without LFED being installed too.
Odd, works fine here.. Wherever you run GB6 .PRG from then just put GB6B33.PRG there, but not sure if you need the RSC file as well.. but otherwise should run as before..
exxos wrote: Mon Jun 07, 2021 5:52 pm Odd, works fine here.. Wherever you run GB6 .PRG from then just put GB6B33.PRG there, but not sure if you need the RSC file as well.. but otherwise should run as before..
Oh its in the BIN folder, wrong file is there.. its looking for GB6.O .. just rename it..
pixelpusher
exxos wrote: Mon Jun 07, 2021 5:54 pm
Renaming helps to start it, it still doesn't recognize an FPU nor an LineF emulation and just reports that no FPU was found when trying to start the FPU test.
pixelpusher wrote: Mon Jun 07, 2021 6:38 pm Renaming helps to start it, it still doesn't recognize an FPU nor an LineF emulation and just reports that no FPU was found when trying to start the FPU test.
:( ill do a debug version so it outputs what the value in the cookie it finds , see if it gives any clues...
Return to “SOFTWARE”
