Questions regarding a 4mb update on 1040STF, motherboard C070523-001 REV. C
Globox
Re: Questions regarding a 4mb update on 1040STF, motherboard C070523-001 REV. C
Post by Globox »
exxos wrote: Thu Sep 17, 2020 10:47 pm Nope. Like I suggested, @Steve is the one to send your machine to figure it out.
Haha I know it would be smarter, but I don't feel like giving up just yet!
I'm going to get a diagnostics cartridge anyways, would that also see if there's a problem with the shifter?
Globox wrote: Thu Sep 17, 2020 11:03 pm I'm going to get a diagnostics cartridge anyways, would that also see if there's a problem with the shifter?
If the shifter is part alive then you can do colour tests, but I suspect your missing the 16Mhz output, in which case the system wont even try to boot the cartridge. other than try a different shifter, or indeed MMU,GLUE etc, you can't do much without a scope. It may just be cheaper to get a new motherboard.
Globox
Post by Globox »
exxos wrote: Thu Sep 17, 2020 11:16 pm If the shifter is part alive then you can do colour tests, but I suspect your missing the 16Mhz output, in which case the system wont even try to boot the cartridge. other than try a different shifter, or indeed MMU,GLUE etc, you can't do much without a scope. It may just be cheaper to get a new motherboard.
Can't try with my other Atari's shifter because it's not socketed, and I think it's best if i don't get that one involved :p
Was planning on upgrading both of them to have 2 4mb Atari's in the end anyways, one for the music studio and one for the gaming room, so I think i'm just gonna buy another one.
I see Atari ST's are still relatively cheap second hand, over here at least (finding one for 50€ - 100€ should be possible)
Unless I broke the shifter adapter, my problems are already solved if I install the mod on the new one i'm gonna get (with all the knowledge I have now, and 1000x more care and thorough testing with multimeter), but it feels sad declaring this one dead for good, just because finding a new one is cheaper.
I really wanna get this machine running again!
Anyways, there's not much I can do for now, so I'm gonna start looking for a new Atari :P
Thanks a lot for the help guys, this seems like a really nice community!
Think i'm gonna learn a lot browsing this forum!
Globox
Post by Globox »
Another question, how likely is it that my problem is a dead shifter chip, probably due to bad soldering on the shifter adapter?
I see you can find those online for 20€, so that would be an easy fix...
Globox wrote: Fri Sep 18, 2020 7:27 pm Another question, how likely is it that my problem is a dead shifter chip, probably due to bad soldering on the shifter adapter?
It is purely guesswork that it is a dead shifter as you are unable to measure anything.. As it is a guess, it may well be wrong.
Globox
Post by Globox »
Aha...
New Atari it is :p
I wanna test if the shifter is dead by trying the shifter of the new one I'm getting
I can't break the new shifter when doing that, right?
Also, if it actually turns out to be a dead shifter, do you think I could trust this?
https://nl.aliexpress.com/item/4001124747658.html
It's the only place online that seems to be selling them
@Globox im not sure i would order Atari stuff from China. Exxos has them in his store but obviously Aliexpress is cheaper.
Quite often they will cancel your order and refund you saying the quality is bad. I had this when I saw blitters for sale on there.
Globox
Post by Globox »
PhilC wrote: Fri Sep 18, 2020 8:47 pm @Globox im not sure i would order Atari stuff from China. Exxos has them in his store but obviously Aliexpress is cheaper.
Oh damn i checked exxos' webstore already, must've looked over it... :P
Globox wrote: Fri Sep 18, 2020 8:54 pm Oh damn i checked exxos' webstore already, must've looked over it... :P
https://www.exxosforum.co.uk/atari/store2/#0102
At least you know mine work as I test them all.
Wonder if those are real on aliexpress.. might order one and see , not had to open a dispute for at least a week, so about due for another :lol: :roll:
@exxos might see if they have any bad dmas :lol:
Return to “RAM UPGRADES”
