Turrican II intro music
68030 + SDRAM + IDE
Re: Turrican II intro music
Ok this fixes it for me... please confirm someone...
tf536r2_2020_8_1.zip
(18.75 KiB) Downloaded 323 times
Its basically caused by the 030 being fractionally slower on the 68000 bus when given the same clock. You can all thank @exxos, GemBench and the Atari ST for the fix. As i've pinched this from what i was doing on the ST.
FluffyRedLobster
Post by FluffyRedLobster »
So with this firmware...
Turrican 2 dodgy ADF written to floppy - perfect :)
Turrican 2 WHDLoad slave 1.8 - perfect :)
Turrican 2 WHDLoad slave 2.1 - perfect :)
Damocles text timing (WHDload slave 1.3) - perfect! :D
It's a winner!
I'm not quite sure what to say other than cracking job TF! And the ST folks :)
TF536 full copper top 030, Amigakit SD adapter, A500 Rev6a, KS3.1, Boobip 2MB w/ Gary Adapter
arkadiusz.makarenko
Post by arkadiusz.makarenko »
I have just finished testing, and sound issues are gone on my TF536 as well :)
Thank you for this bugfix.
~ Stanislaw Lem
Thanks i've pushed this to the github binaries area.
go0se
Post by go0se »
Sound issues are no longer present on an A500+ and a ... CDTV. Great stuff!
The new firmware also appears to have reduced the boot time of a SD card WB3.9 FFS image significantly compared to the previous firmware that I was using... :o
Perhaps I'm behind the curve and have missed a previous update? I think I need to investigate this one further! :)
I've added an r1 firmware to the binary on github too.
arkadiusz.makarenko
terriblefire wrote: Sat Aug 01, 2020 9:36 pm I've added an r1 firmware to the binary on github too.
I am curious if this will fix A2000 issue.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Sat Aug 01, 2020 9:39 pm
Unlikely but possible. I have another thing i want to do before A2000.
FluffyRedLobster
go0se wrote: Sat Aug 01, 2020 9:18 pm Sound issues are no longer present on an A500+ and a ... CDTV. Great stuff!
I can't say I noticed a boot time improvement but I wasn't really paying that much attention as I never felt boot times were slow in the first place.
I just did a quick sysinfo drive speed test though (I know, it can't be trusted) and it now averages around 2.9 - used to be more like 2.7. So who knows!
go0se
Post by go0se »
Further (read proper) tests indicate that the boot times are equivalent on average with the previous firmware - i.e. absolutely fine but not any faster. I fell foul of having multiple Workbench images and Amigas sitting in front of me and not comparing like for like images so the earlier boot time report was a red herring.
This firmware definitely does seem to have solved the music slowdown issue. I will use it on builds from now on to check stability and for any regression.
Return to “TF536”
