kodak80 blog
kodak80
Re: kodak80 blog
Post by kodak80 »
For my ST ATX board which is now cased in a black Micro ATX case I have ordered these VGA to IDC boards to allow me to used a 16 pin ribbon cable to mount the VGA port somewhere.
VGA to IDC16 adapter gerber.zip
(17.64 KiB) Downloaded 85 times
Re: kodak80 blog
@kodak80 I was going to make some of those but you beat me to it :D
kodak80
Re: kodak80 blog
Post by kodak80 »
PhilC wrote: 02 Sep 2022 23:14 @kodak80 I was going to make some of those but you beat me to it :D
Cool. I can also confirm that the VGA 16 pin header works fine. I tested it today. :D
Still need to test parallel and serial headers.
For the dual TOS, I am using 1.04 with IDE patch and 2.06. 1.04 boots the IDE CF card fine.
atari030
Re: kodak80 blog
Post by atari030 »
This is damned exciting. Did you come up with a way to hook up an Atari KB?
kodak80
Re: kodak80 blog
Post by kodak80 »
I have 1 working ST ATX system at the moment but I am thinking that the pull-up resistors on it need to be changed on the next board I am building.
The ST ATX system is currently using 10K/4.7K pull-up resistors and I note on the H4/H5 we used 2.2K/1K pull-up resistors.
ST ATX BUS PULLL_UPS:
Bus Pull-ups ST ATX.jpg (61.55 KiB) Viewed 2242 times
I tried adding a 64 pin expander board onto my existing ST ATX system to relocate the CPU and add a 2nd 64 pin socket but this caused my IDE disk to get corrupted. I have removed the expander and tings are stable again with the IDE CF drive.
On the next board, I have decided to socket the SIL resistors although there are still 3 SMD resistors (R44, R45, R46) to consider:
Board 3 SILs socketed.jpg (210.37 KiB) Viewed 2236 times
Re: kodak80 blog
Hi @kodak80 I've finished my ATX board but have a number of issues with it that I've not worked out yet.
I get bad ghosting on the display, Tos 2.06 fails the memory test after 8 dashes and the floppy doesn't work.
I wondered if there was any fixes that need applying to a standard V1.1 board other than the ISA one?
atari030
Re: kodak80 blog
Post by atari030 »
Is that your first board, Rob?
kodak80
Re: kodak80 blog
Post by kodak80 »
PhilC wrote: 10 Nov 2022 17:15 Hi @kodak80 I've finished my ATX board but have a number of issues with it that I've not worked out yet.
No, the only fix is for the ISA slot. There are 2 jumpers for switching TOS versions. One switches the TOS loaded from the ROMs and the other jumper is to switch on/off 256k decoding. Both jumpers need switching if you have TOS 2.06 / 1.04 in the ROMs. A GAL/PAL IC11 has the IDE and TOS decoding so you could also check this is programmed correctly. Does TOS 1.04 load without issues?
I also use 1.04 with the IDE patching applied so the IDE boots from both TOS 2.06 and 1.04.
kodak80
Re: kodak80 blog
Post by kodak80 »
atari030 wrote: 10 Nov 2022 22:20 Is that your first board, Rob?
I am now on my third working board. The third one has the SILs in headers so I can test the CPU expander and test PC-Speed etc. I am currently using the original SIL resistors in the BOM for the ATX board.
kodak80
Re: kodak80 blog
Post by kodak80 »
As shared on other forums. My ISA Cartridge adapter works fine with bodge wires from underneath the GLUE IC (pins 17 & 18) for ROM3 & ROM4.
Cart Adapter-routed_2022-09-08.zip
(46.96 KiB) Downloaded 110 times
Cartridge slot fits flush with the external ATX case so will not allow cartridges in cases to be fitted. I am working on the next version of the adapter with the cartridge slot sitting outside the ATX casing...
Cubase 3.0 re-created dongle works
IMG_8174 - Copy.JPG (79.75 KiB) Viewed 2032 times
IMG_8175 - Copy.JPG (69.25 KiB) Viewed 2032 times
Diag cart works
IMG_8186 - Copy.jpg (71.64 KiB) Viewed 2032 times
IMG_8189 - Copy.jpg (53.46 KiB) Viewed 2032 times
IMG_8188 - Copy.jpg (24.92 KiB) Viewed 2032 times
DoG's MV16 cartridge works. Worlds first Atari ST ISA sound card...
IMG_8190 - Copy.jpg (57.26 KiB) Viewed 2032 times
IDC 26 pin connectors for Parallel and Serial need a fix board to correct the output when using standard IDC to DSub connectors. I tested the IDC PCB fix by printing to an old dot matrix printer.
Screenshot 2022-09-25 094428.jpg (34.54 KiB) Viewed 2032 times
26 pin Header Fix gerber 2.54mm.zip
(25.2 KiB) Downloaded 63 times
Users browsing this forum: ClaudeBot, PhilC and 25 guests
