The TF1260 rev1 arrives!!! Oh boy!
supaduper
Re: The TF1260 rev1 arrives!!! Oh boy!
Post by supaduper »
oh Ok I will go over it with a fine tooth comb :)
supaduper wrote: Sun Jan 26, 2020 4:50 pm oh Ok I will go over it with a fine tooth comb :)
Ah i think i realized what might be happening... I've got a 6ns RAM CPLD..
EDIT: try this
tf1260r1_2020_01_26_alpha.zip
(53.27 KiB) Downloaded 176 times
the 6ns suffix is for 6ns CPLDs. Otherwise use the standard one.
supaduper
Post by supaduper »
I was racking my brains last night and was just about to mention again that I had put two 10 ns cplds on my build and also I have 1k resistor arrys on all my pads except the 10k one by the multiplier, but I scanned your Stream again and noticed you have some 220 ohm ones on yours will that matter Steve ?
I will try the jeds when I get up from my bed lol
Yeah the data bus ones absolutely have to be 220 or 0 ohm. 1k is too high. That’s the 8 in a fan around the RAM.
Also the resistor inside the TF logo needs to be 220z
supaduper
Post by supaduper »
ok cheers. I have now took the 10ns ram cpld off and put a 6ns like yours on, so we are on the same song sheet, will now swap out those 1k resistor arrays
supaduper
Post by supaduper »
Yep that did it, we are in like Flyn :)
2nd TF1260 r1 lives ! with 128mb ram
Also never mention resistor arrays again lol , now I know what it is like to soldier ants..geddit ? I`ll get me coat
TF1260 r1 first contact.jpg (176.38 KiB) Viewed 4161 times
!Message from: Moderator
@supaduper, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
I’m going to flip the 8 of those to the bottom so they can be auto assembled.
Higgy
Post by Higgy »
Great work guys. Glad to hear it was not A1200 motherboard revision related.
Can you please remind me of the main Rev 1 goal, was it mainly to increase past 66/75Mhz reliably?
On aside I was singing all your praises at the SWAG Workbench 2020 AMIGA meet. AmigaKIT said they will be releasing an 8mb A1200 RAM expansion for £60 soon, its good to hear that there are some sellers who are seeing the light and offering reasonably priced kit.
Todays iteration of the firmware
I identified a glitch that will prevent operation (causes a bus lock) at ~80 MHZ. Its by not means fixed everything but wanted to push todays changes out for testing.
tf1260r1_2020_01_27_alpha.zip
(54.13 KiB) Downloaded 158 times
supaduper
Post by supaduper »
Will try this first thing in the morning Steve
What glitch were you getting ? as I set CPUSPEED to 80mhz and I ran Quake on loop with no problems
Return to “TF360”
