TF Riser Revision 0 Arrives
TF CD32 Riser
Re: TF Riser Revision 0 Arrives
I’m more than happy to put my cube ide project on github for people to start playing with.
Video out works as does the riser accelerator port :)
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Mon Jan 20, 2020 11:32 am I’m more than happy to put my cube ide project on github for people to start playing with.
Yes please.
I am waiting for my gear to arrive. I just bought cd32.
My f407 dev board arrived today, so I should be ale to start learning how to use hid libraries.
I may be wrong but this device may be only to serve as a host for 1 device with no support for hubs.
I did find this in stm32 usb docs:
Can the USB host library handle devices connected through a USB HUB?
No.The USB host library does not support HUB class.
Does the USB host library allow to handle multiple configuration devices?
No. Only single configuration devices are supported
So this might be limitation for mouse+keyboard combo?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Jan 21, 2020 11:01 pm Yes please.
I'm expecting to do a second revision of this board with 2 ARMs on it. But yeah thats probably why only the keyboard shows up.
Why not just build the riser rather than play around with dev boards? I never found dev boards to be particularly good for learning on.
arkadiusz.makarenko
terriblefire wrote: Tue Jan 21, 2020 11:04 pm
I am planning to do the order this week and build it over following weekend.
I guess meanwhile I might be able to hijack gotek and debug firmware there :D
~ Stanislaw Lem
You should be able to get a Blue Pill and a cheap ST Link v2 next day delivery from Amazon. You’ll need the ST Link either way.
Generally we might not want to use the USB library and maybe find porting the MiST USB code is better.
arkadiusz.makarenko
May I ask what bom is for non ARM stuff?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Jan 22, 2020 10:41 pm May I ask what bom is for non ARM stuff?
Here is the full bom from the eagle file.
cd32_riser.txt
(7.61 KiB) Downloaded 194 times
arkadiusz.makarenko
terriblefire wrote: Wed Jan 22, 2020 10:47 pm
cd32_riser.txt
Thank you.
Parts ordered in Mouser. It took me a while to find connectors. I had to order db23 on ebay.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Thu Jan 23, 2020 6:54 pm Thank you.
Ah supaduper would have set you up with a DB23.
Looking over the MiST firmware.. it basically has USB hub support via reasonably clean interface for a max3421e usb chip.
So essentially if we write something that acts like that API in MiST then we would get all that support + FAT + Ethernet etc.. at least in theory. Then we'd need to interface it to the Amiga somehow but I can do that part. Might need a bigger CPLD.
Return to “TF CD32 Riser”
