diagrom showing 0 fastmem on new board
TF530 - 63030 + RAM Board
oggie
Re: diagrom showing 0 fastmem on new board
Post by oggie »
Mine does have an FPU in it.
8 Bit Dreams
Post by 8 Bit Dreams »
oggie wrote: Sat Dec 28, 2019 2:20 pm
Is there a known issue that it can't do 40MHz?
TF530 works fine @40Mhz, seems to me You have a problem on ram cpld.
Wich Revision do You have? On rev.3 there is a 0603 cap beneath CPU that doesn't need to be installed, if You do - card will not work
oggie
Post by oggie »
It's a rev3.
I did install it in both boards, and it works fine in the 30MHz one:
https://photos.app.goo.gl/KpW9vDqXzvmVW9QG6
From github page:
2 0.1uF 0.1UF-25V(+80/-20%) 0603-CAP C16, C17 CAP-00810
So I should have only installed the one beside the FPU?
8 Bit Dreams
don't have any TF530's to make a photo,
i mean one on the top side beneath CPU socket
oggie
Post by oggie »
There isn't one on the topside under the cpu for rev3:
https://github.com/terriblefire/tf530/b ... v3_top.png
8 Bit Dreams
sorry, gave You wrong information, it is not beneath CPU its near RAM cpld, haven't built these for a year now... :oops:
Found this picture in net:
this one doesn't need to be soldered on!!
resistors need to be 1k - 2k, same for RNs 1k - 2k,
i used 2K on my builds
oggie
Post by oggie »
yes. I didn't solder that one.
oggie
Post by oggie »
All my resistors are 1K BTW.
So I happened to have a spare 40MHz cpu. I installed it as well as redoing a few solder joints.
I don't see the strange artifacts on the screen anymore, and I'm able to successfully run a fastmem test of all 2mb, but the moment it completes in daigrom and I hit the esc key to go back to the main menu, it locks up.
It's weird that it's able to complete the fastmem test successfully every time though.
oggie
Post by oggie »
I don't have a lot of free time, so I finally found time to look at this again. After retrying solder joints etc and every other suggestion, I decided to put in a 33MHz crystal instead of the 40MHz one. Guess what? It's stable at 33MHz....
So underclocked it works. I don't have a spare 40MHz FPU to see if it's the culprit at 40MHz however. I've swappped the CPU and it still had the issue, so I'm starting to think my FPU is a fake....
dalek
Post by dalek »
The recent lots of 40Mhz FPUs from China bay I've found to be very hit and miss. From the ones I've got, I reckon around 1 in 3 don't do 40MHz, and the printing wipes away easily when rubbed with IPA, indicating a relabelled part.
Return to “TF530”
