TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
supaduper
Re: TF1230 Beta Interest (Open Source)
Post by supaduper »
Ok so I was having loads of probs CF not working then working Blah Blah blah, so in the end I swapped out the Ram and the CPLD and Viola ! its all 100% working so must have damaged my cpld with all the strangling lol
all cf cards work, cheap and nasty and the top brass ones too its all good, well happy.
wow a TF1230 for the A1200 under £100 ( without CPU and Depending on ram size) ,who`d av thunk it, Fantastic work Mr Leary 8-)
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Tue Sep 14, 2021 9:57 am Has anyone tried the TF IDE drive yet? it should work exactly like the TF1260 with the ehide.device.
My amiga crashes when running loadmodue ehide.device
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Sep 14, 2021 11:38 am
Crashes or reboot? its supposed to reboot.
arkadiusz.makarenko
terriblefire wrote: Tue Sep 14, 2021 11:44 am
Crashes, but need to check if after keyboard reset it is ok.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Sep 14, 2021 11:47 am
I will check with Erique if there is 060 code in the driver or something.
arkadiusz.makarenko
terriblefire wrote: Tue Sep 14, 2021 11:48 am
Ok. So what happens it simply doesn't reset correctly, but after manual keyboard reset it loads driver fine.
I managed to load SysInfo from external ide, and i got this
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Sep 14, 2021 12:09 pm
Ah then we might have a soft reboot issue like the TF330r2
Ok so it works we just need to make it fast.
supaduper
Post by supaduper »
ehide device boots fine with me and keyboard softboot works also , and the speed is not too shabby, and always give the partion a different number as I see you have duplicated a device number ( The one with the under_score ) normally not a problem but it will stop confusion :)
Lemaru
Post by Lemaru »
supaduper wrote: Tue Sep 14, 2021 10:49 am wow a TF1230 for the A1200 under £100 ( without CPU and Depending on ram size) ,who`d av thunk it, Fantastic work Mr Leary 8-)
I guess that'll be the rough pricing for an assembled board from a builder? And rough cost for a build it yourself (including CPU) is under £80
kulamario
Post by kulamario »
Twice time amiga frozen in EBM
Return to “TF330”
