General Stuff(tm)
Re: General Stuff(tm)
stephen_usher wrote: Tue Sep 08, 2026 11:48 pm I've just got home from my partner's place and tested the "high quality" N64 controllers.
To be fair the mouldings are good and the buttons etc. feel OK...
On one controller the analogue "down" works only if you pull it down a little, then it goes up.
On the other controller the D-pad does left and down if you press left, most of the time.
Otherwise they're fine.
I didn't expect anything better for £23 including delivery though to be honest.
I got lucky and managed to bag a Competition Pro controller fro a tenner. It was filthy though and missing screws, however it has proved to be a decent controller after some maintenance and it does have turbo switches for all of the buttons.
Not sure how it ended up this way, never having had Nintendo consoles BITD, but I've ended up with a Famicom, a NES, a SNES, an N64, a WII and a WII-U, not to mention numerous Gameboys and a Switch Lite!!!
Good job I have enough space to store them...
OK, well those controllers were good enough to test the system but the analogue stick on both doesn't work correctly in many games and in Mario ones doesn't work at all. Definitely not fully compatible. It's a pity as otherwise they feel pretty good quality.
The SummerCart64 works well and was pretty easy to update and get working.
stephen_usher wrote: Wed Sep 09, 2026 11:59 am OK, well those controllers were good enough to test the system but the analogue stick on both doesn't work correctly in many games and in Mario ones doesn't work at all. Definitely not fully compatible. It's a pity as otherwise they feel pretty good quality.
Trying to remember if some of the games I have didn't work with the analogues stick, I'm sure some didn't. Will try and have a look when I get home from holiday.
stephen_usher wrote: Wed Sep 09, 2026 11:59 am The SummerCart64 works well and was pretty easy to update and get working.
Nice :)
I ordered one of those HDMI adapters you suggested. I've also ordered a couple of real controllers off eBay and a controller memory for saving as game keep complaining.
I've been playing Rayman 2 this afternoon. It's quite fun despite the number of cut scenes.
It's very definitely a late 1990s gaming experience where everything seemingly had to be re-imagined in 3D, but with a terribly small polygon count and bad textures. :-)
Oh, and for some reason dingey, dark colours.
stephen_usher wrote: Wed Sep 09, 2026 3:10 pm I ordered one of those HDMI adapters you suggested. I've also ordered a couple of real controllers off eBay and a controller memory for saving as game keep complaining.
There is also the memory (RAM) cart that goes in the console itself. It isn't obligatory but some games do need the extra RAM to run at all.
As for the savegame carts, yes, it very annoying when it continually bugs you about not being able to save a game.
stephen_usher wrote: Wed Sep 09, 2026 3:10 pm I've been playing Rayman 2 this afternoon. It's quite fun despite the number of cut scenes.
I need to pull mine out again to play a few more games, but I've been on other things of late.
stephen_usher wrote: Wed Sep 09, 2026 3:10 pm It's very definitely a late 1990s gaming experience where everything seemingly had to be re-imagined in 3D, but with a terribly small polygon count and bad textures. :-)
Yes, it seemed to be the way of things at the time, where it had to be 3d or it was rubbish, but as you say, small polygon counts and textures that look like a melted bar of chocolate!!!
The OneROM segment of the latest Adrian's Digital Basement II video has got me thinking about how to implement a OneROM switcher for the Sinclair QL.
Here's the video:
I could use the start-up sequence from my diagnostic ROM, copy a program out of ROM into RAM and then run that.
Well, if I'm copying a program into RAM then maybe I could write that in C, which would be easier than assembler. If I'm doing that then I will have to write a set of libraries for system access and memory allocation, which I can also do in C, which would be easier than in assembler...
This opens up a lot of possibilities, not least of which would be a version 2 of the diagnostic ROM with a menu system, keyboard tester, etc.etc.etc.
@stephen_usher, @Icky did a flash rom a while back that needed just the software writing? That might make a good base to start with?
PhilC wrote: Fri Sep 11, 2026 9:05 am @stephen_usher, @Icky did a flash rom a while back that needed just the software writing? That might make a good base to start with?
My diagnostic ROM start-up code can be used, with the initial memory test. I then just need to write a routine to copy the program blob into RAM and call it. The C code would have to have a set of libraries written to do all the screen display stuff and I/O.
QDOS programs need to be written as position independent code, which is exactly what I need, so using a QDOS C cross compiler should, assuming that the start-up library doesn't do any system calls, just work.
The plans for the N64 are comping together.
Yesterday the expansion pack arrived. It works fine and gives a lot of games some extra capabilities. Some get higher resolution, some just have more bells and whistles.
I picked up the first true N64 controller this evening and the joystick action is like chalk and cheese. The Amazon controllers are obviously using the original plastic moulds for the controllers, just with the "Nintendo" branding removed.
I decided to give the console and controller a proper deep clean and then used furniture polish to seal the surface and make them look like new.
Tomorrow the second controller and memory pack should arrive. The HDMI adapter is now in the country as well and transferred into the hands of InPost.
It looks like AllTheThings(tm) are going to arrive today. :-)
