TF1260 stuff
Re: TF1260 stuff
matt020 wrote: Thu Jun 24, 2021 12:42 am Is that A1200 motherboard IDE speed, or TF1260 IDE speed?
TF IDE Speed. Onboard IDE timing is pretty much dictated by gayle.
trixster
Re: TF1260 stuff
Post by trixster »
ekalkici
Re: TF1260 stuff
Post by ekalkici »
GadgetUK164 wrote: Wed Jun 23, 2021 3:33 pm Stephen said I was OK to post this:-
With the latest firmware, IDE is showing 5.3MB/s (up from 1.9MB), and bus test is showing at least 100% improvement I think too!!! Runs way way better =O
I would be interested to know (once people get onto a later firmware) what speed you get on IDE, and what card / adapter / drive you use! I suspect the CF card I am using could be better.
Very good results , escpecialy ide speed is. I got 1.9 mb with Kingston CF 4GB. Standart old firmware . Will get Sandisk Ultra and Exterme 8-16 gb ones to test.
Alson can i ask how many mips on sysinfo you get with new firmware @ 62.5mhz . With standart old one i get 48.75 mips. Just a refernace test.
Re: TF1260 stuff
ekalkici wrote: Sun Jun 27, 2021 9:03 am Alson can i ask how many mips on sysinfo you get with new firmware @ 62.5mhz . With standart old one i get 48.75 mips. Just a refernace test.
Sysinfo report is exactly the same. Which shows how useless sysinfo is as a metric. Sysinfo tests all run out of cache.
GadgetUK164
Re: TF1260 stuff
Post by GadgetUK164 »
Out of interest, can you think of a scenario where the lack of timing fixes could stop a CPU running beyond 62.5Mhz? I've just ordered ANOTHER 75Mhz chip - this time from Russia. The RC75 I got today again wont go past 62.5Mhz =/ It's a super lottery trying to find an LC or EC chip that will go beyond 62.5Mhz. That will be chip number 4... I will sell a couple of them and keep one for the TF360 if that has a run at some point.
alenppc
Re: TF1260 stuff
Post by alenppc »
GadgetUK164 wrote: Thu Jul 01, 2021 8:15 pm Out of interest, can you think of a scenario where the lack of timing fixes could stop a CPU running beyond 62.5Mhz? I've just ordered ANOTHER 75Mhz chip - this time from Russia. The RC75 I got today again wont go past 62.5Mhz =/ It's a super lottery trying to find an LC or EC chip that will go beyond 62.5Mhz. That will be chip number 4... I will sell a couple of them and keep one for the TF360 if that has a run at some point.
In your case, this is probably a CPLD issue. I've seen a few 10ns cplds that won't go past 62mhz. Replacing the RAM cpld would normally fix this.
ekalkici
Re: TF1260 stuff
Post by ekalkici »
Do you have no chance on 75 mhz or work a bit then crash when load or etc. I tried with different motherboards and timing fixes , results were same. My card work a bit stable at 75 mhz with rev5 then crashes. Maybe with new firmware can be stable @ 75 mhz.
My CPLD's are 10ns. And have heatsinks on both CPLS and 060. Fan cooling from right side.
Re: TF1260 stuff
I think i've said this 100 times now..
The firmware needs an update to get more speed. I need to make wholesale changes and i've not had time.
Dont waste your time and money on this until i've got this sorted. I just need to sort my basement damp out first.
GadgetUK164
Re: TF1260 stuff
terriblefire wrote: Fri Jul 02, 2021 10:22 am I think i've said this 100 times now..
The firmware needs an update to get more speed.I need to make wholesale changes and i've not had time.
Sorry, I didn't see that previously! I assumed it was just the CPUs I am trying (and I suspect it is tbh - they are all rev 4's). Also, others are running much faster already so this led me to think it was either the CPUs or my 1200 (regards timing fixes).
GadgetUK164
Re: TF1260 stuff
alenppc wrote: Thu Jul 01, 2021 9:53 pm
Thanks! I wasn't aware that different speed CPLDs might be needed - I will hang fire until Stephen has time to work through tweaks etc. Not in a rush - can see if that other 75Mhz (looks like R5) makes a difference when that arrives.
ekalkici wrote: Fri Jul 02, 2021 8:42 am
Nah, all three just freeze the system straight after selecting 75Mhz - pretty sure its due to them all being rev 4 CPUs though tbh!
Return to “TF360”
