TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
alenppc
Re: TF1230 Beta Interest (Open Source)
Post by alenppc »
arkadiusz.makarenko wrote: Fri Sep 10, 2021 9:26 pm As a tester, I do my best to report unexpected behaviour and I try to reproduce issues reported by other people.
I do not suggest the cause, as I don't have enough knowledge to do it ,but still I think it may be relevant to TF in troubleshooting.
You misunderstood me :) But I guess I should have explained better. In fact, I reproduced your findings perfectly. I think our two machines behave in the same way.
I was replying more to the comment of "which ram are you using", because we already know which types of RAMs work so let's not start swapping them for no reason.
Danoo
Post by Danoo »
Ok the CPLD finally arrived yesterday arvo, still waiting for the memory, I have pinched some off a 536 for now, bit of a PIA re-soldering recycled chips but I wanted to finish the card. ;) .
Finished the build this morning, tested with DiagROM on a 2B Motherboard
Testing
Testing
Solid as rock on a 2B (with original 3.1 ROMS and firmware dated 21 August) ran a variety of different software over a 3-4 hour period in the backshed. Ambient temperature in the shed was around 32C fairly warm here today. CPLD and CPU temperature were around 45-50C (no heatsinks attached). Considering how hot the ambient was no issues with temperature.
AIBB: 14761 Dhrystones/Sec, Memory 11.96 MB/Sec
Sysinfo: DH0 drive speed 1,771,243 Bytes/Sec
2B
2B
As most have already stated, no issues what so ever with the 2B, will try a 1D4 in the next few days.
Life is really simple, but we insist on making it complicated - Confucius
kulamario
Post by kulamario »
Board 1D4
Kick 3.1
Memory test working whole night
This what I see this firmware (all from yesterday)stop working IDE on 2B board
Ok so just IDE lockup issue left?
kulamario
Post by kulamario »
Yes
Try this one
<deleted>
supaduper
Post by supaduper »
Still blank screen on my 1D4, but works 100% on the 2b
Does it boot DiagROM on your 1D4?
supaduper
Post by supaduper »
need to burn some roms
** Edit
Diagrom works fine on 1d4, sees the TF1230 030 CPU and the 128mb that I have on this Board
I used the Drive test with CF card in the A1200 and diagrom says `No Disk Found`
said it is waiting for the Drive RDY signal
**EDIT 2
So I have some activity using a different CF , was using a Sandisk , also tried Kingston and get couple of flashes and then then to the Kickstart Screen
alenppc
Post by alenppc »
terriblefire wrote: Sun Sep 12, 2021 5:26 pm Try this one
tf1230r1_main_top.zip
We have a winner. Working perfectly on my A1200 now.
Return to “TF330”
