agranlund
Post by agranlund »
Implemented speed throttling to prevent ST emulation from running too fast.
Defender of the Crown was the very first game I had on the ST so just hearing that music fills me with nostalgia!
I hadn't used a GUI based computer before and remember not being able to start the game that first evening when the computer was unpacked - I didn't grasp the concept of double-clicking on icons until the day after when it probably happened by accident :)
Sampled sounds through YM are recognisable but of very poor quality due to the way the emulated machine is accessing some of the real hardware directly and others being emulated. An interesting problem to deal with some other time..
Cyprian
Post by Cyprian »
cool,
do you have SHIFTER emulation or that game is OS friendly and it works on any GFX card?
http://260ste.atari.org
DrZiplok
Post by DrZiplok »
agranlund wrote: Sun Jul 07, 2024 11:44 am
DoG wrote: Sun Jul 07, 2024 10:59 am Hmm. Those memory chips on the SIMM ain't cheap... :o
I'm not sure of an exact BOM cost for the motherboard, I'm guessing at €200+ excluding the IC's that are out of production?
Using the provided BoM for MLB, three 16M SIMMs and a ROM stick, as a retail US Mouser customer, $380.
agranlund
Post by agranlund »
Cyprian wrote: Fri Jul 12, 2024 5:20 pm do you have SHIFTER emulation or that game is OS friendly and it works on any GFX card?
Yep it runs under emulation. It's a bit of on-and-off work in progress and I figure raster emulation is probably the next thing on the list.
Oldskool
Post by Oldskool »
Maybe stupid question.
Currently soldering some stuff but have a question concerning the diode direction.
Is this the correct direction (just to be sure)?
diode direction.JPG (9.93 KiB) Viewed 1370 times
DrZiplok
Post by DrZiplok »
Oldskool wrote: Mon Jul 15, 2024 9:26 am Maybe stupid question.
Diode orientation
Diode orientation
Screenshot 2024-07-15 at 9.51.02 AM.png (26.89 KiB) Viewed 1315 times
From the PCB design file, front fab layer.
Oldskool
Post by Oldskool »
Thanks Herr Dr.
Oldskool wrote: Mon Jul 15, 2024 9:26 am Is this the correct direction (just to be sure)?
I get this wrong during assembly. Every. Single. Time.
:oops:
agranlund
Post by agranlund »
Note to self: Backup CF card before working on bus logic...
One very silly mistake and I found myself with a semi-trashed filesystem.
Ok, so I've been meaning to re-partition and reinstall anyway but would rather have chosen the moment myself :)
In better news:
Bus logic should be better and the machine can now run properly on clock configs other than 96/48mhz.
Tested with 16, 25, 32, 48 and 50 mhz oscillators in both 2X and 1X cpu multiplier modes.
Not 100% sure how to go about peripheral wait states. They are all ticking from the bus clock and are unscientifically tuned for around 50mhz, they would potentially wait longer than necessary if using a slower bus clock.
I have a spare jumper going to the cpld and I'm thinking it could be used for selecting between 50 or 32mhz tuned waitstates.
Next up would be nice to get ram burst going to feed the L1 quicker, and to reduce the dramatic cost of write-misses when copyback is enabled.
But I should probably re-install and configure Mint on my CF card first.
230, a new record for Raven :)
agranlund
Post by agranlund »
Badwolf wrote: Mon Jul 15, 2024 7:52 pm I get this wrong during assembly. Every. Single. Time.
I had to cross reference in Kicad and datasheets during assembly too for this one and a few other components :)
Wouldn't hurt to make the silkscreen a bit clearer in some places for future revs.
