TF1260 stuff
Re: TF1260 stuff
GadgetUK164 wrote: Sun Jun 06, 2021 9:48 pm That new compiled version works OK here too! Stephen - Are the clock speed increments related to the board design btw or the FPGA code?
Its the clock multiplier chip.
https://uk.rs-online.com/web/p/clock-sy ... s/1628970/
neilshak123
Re: TF1260 stuff
Post by neilshak123 »
The updated CPUSPEED works better for me too - no more garbled output when clocking to 75 and can now clock back to 50 without it crashing. Thanks!
matt020
Re: TF1260 stuff
Post by matt020 »
It's interesting that all these people needed this modified CPUSPEED application. I never had a problem with the original.
Re: TF1260 stuff
matt020 wrote: Mon Jun 07, 2021 11:25 am It's interesting that all these people needed this modified CPUSPEED application. I never had a problem with the original.
I suspect non-standard maths libs may be part of the issue.
GadgetUK164
Re: TF1260 stuff
Post by GadgetUK164 »
I never needed it - just wanted to test it =D
GadgetUK164
Re: TF1260 stuff
terriblefire wrote: Sun Jun 06, 2021 10:40 pm
Ah, I see! So the multipliers are fixed! I am guessing if crystal was dropped to 20Mhz, that would slow access down to Amiga chip set etc? ie. perhaps allow me a CPU speed of 66Mhz, but reduce some performance when its in the other domain (due to that drop from 25 to 20Mhz)?
Re: TF1260 stuff
GadgetUK164 wrote: Mon Jun 07, 2021 5:12 pm Ah, I see! So the multipliers are fixed! I am guessing if crystal was dropped to 20Mhz, that would slow access down to Amiga chip set etc? ie. perhaps allow me a CPU speed of 66Mhz, but reduce some performance when its in the other domain (due to that drop from 25 to 20Mhz)?
The trouble is that the only frequency that the spec says the multiplier works with over the whole range is 25Mhz. I have plans to use the clock undoubled... but i need time to get to it.
Duncan
Re: TF1260 stuff
Post by Duncan »
alot happening with this. looking forward to trying out the new sweeties :)
Duncan
"I've seen things you people wouldn't ken, I've seen motors on fire, on the shoulder near Kinryan, I have watched vejazels glitter in the dark, at the black Trongate, awe these moments, will be lost in time, like beers ... when I'm hame. Time to fry"
E-Penguin
Re: TF1260 stuff
Post by E-Penguin »
Does the TF1260 support autoconfig? I'm trying to get it running on my aca500plus but no luck so far. One of the system information screens suggests there's an autoconfig incompatibility but no details.
Re: TF1260 stuff
There is an Autoconfig card but it does t support any other cards being present except Mediator
Return to “TF360”
