STFM case remake
Re: STFM case remake
Another pink prototype print, this time of the removable back panel. One way or another @exxos will get his pink case :)
A few tweaks on the bottom case part and hopefully print out that in the next few days.
:excited: :excited: :excited: :excited: :excited: :thumbup: :thumbup:
Edit:
No need for RF hole though ;)
exxos wrote: Sun Aug 02, 2020 12:29 am No need for RF hole though ;)
Yep - That’s the great thing we can now have whatever we want on there as different slot in options :)
I Just noticed we need to add on the port icons as well.
Icky wrote: Sun Aug 02, 2020 12:34 am Yep - That’s the great thing we can now have whatever we want on there as different slot in options :)
Oh yep.. Plus logo ;). Though icons should be easier now the back is flat printed :)
tony.reynolds
Post by tony.reynolds »
This is superb work, niiiiice job!
;Manually change to secret room.
LDA #$1E ;Set room to secret room. ;2
STA VSYNC,X ;And make it current. ;4
LDA #$03 ;Set the X coordinate.;2
STA VBLANK,X ;4
JMP MovementReturn ;And Exit. ;3
shintek
Post by shintek »
Transparent would look so cool, is that even possible though?
shintek wrote: Sun Aug 02, 2020 3:22 am Transparent would look so cool, is that even possible though?
@shintek - I did look into clear ABS a while back for a different project and most always ends up opaque or frosted. There was one reporting to be truly clear but it was about £50 a reel so didn't fork out to see if it worked or not.
@Icky Nice job :) Can't wait to see the full case
Started on the text for rear panel and then need to do the icons. Will have to see how it actually comes out on the print.
Screenshot 2020-08-11 at 09.14.16.png (326.41 KiB) Viewed 5337 times
Screenshot 2020-08-10 at 20.31.31.png (249.11 KiB) Viewed 5337 times
Just playing around with some more printed parts. Not the best of keyboards its a defunct one. Just need a few tweaks, very minor adjustments. e.g. 1 mm extra on the function key aperture lengthways and width ways as its a little tight.
Return to “3D MODELS”
