Raven060 (luciodra build).
agranlund
Re: Raven060 (luciodra build).
Post by agranlund »
bbisi wrote: Thu Nov 20, 2025 4:22 pm Then I test uiptool.tos 54812k
but always break on start and very short time it shows something like eth failed to get .. usb..
usb ???? they don't find the network driver
The filename and mention of usb makes me suspect perhaps you are using a different uiptool?
You'll want to use "raven/drivers/ne2000/uip.tos" from the release package:
https://github.com/agranlund/raven/rele ... .A1.latest
agranlund
Post by agranlund »
luciodra wrote: Wed Nov 19, 2025 10:36 am Any suggestions on how to improve the whole thing without reading around? ;)
I suggest reading around :lol:
Personally I am really quite fond of Thing Desktop so I am using that instead of the basic desktop that comes as standard with MagiC (or MiNT, I use Thing desktop there too).
I think Jinnee is supposed to be quite a good desktop too but I never tried it.
If you want to use >16 color background images in Thing you'll need plugins and stuff from here:
https://atari.gfabasic.net/htm/imgview.htm
This place has a quite large selection of desktop icons if you want to replace that kind of stuff:
http://aicq.gokmase.com/iconz/index.htm
(I think ol's Thing Neo comes with a bunch of fancy icons, or some version of that which I tested on V4SA did at least)
bbisi
Post by bbisi »
agranlund wrote: Thu Nov 20, 2025 5:38 pm [quote=bbisi post_id=136716 time=<a href="tel:1763655776">1763655776</a> user_id=3502]
[/quote]
[/quote]
[/quote]
You are right. I use an other Version
My other computer is running OSX. But Safari or Firefox in Linux dont connect to raven . Ping is running
agranlund
Post by agranlund »
Oh, and you can make ethernet work in MagiC using the "raven/drivers/ne2000/eneh.xif" driver.
(though you need to rename it because MagiC wants a .mif file extension here)
I have not tested anything advanced myself, after a bunch of reading and trying to configure network in magic I got to the point of traceroute and ping working as expected, was happy for that, and then got sidetracker with other stuff :)
Can't really remember off the top of my head where I got the Magxnet / Magicnet package from, or if it was included with MagiC, and then what configuration was required for the stuff to work.
So that's an additional bit of reading around to get networking working :)
agranlund
Post by agranlund »
bbisi wrote: Thu Nov 20, 2025 6:02 pm You are right. I use an other Version
Just to make sure, are you trying to connect to webserver?
As per the readme file (yes I know, no-one reads documentations and neither do I :lol:) the version of uip.tos that comes in the raven package only has support for FTP connection.
anonymous ftp login
PASSIVE mode on the client you are connecting with.
(so the reason I skipped the HTTP server stuff is I had trouble getting the sources to build that part under OSX, and after a couple of hours of messing around with that I eventually just skipped it because I didn't want to spend even more time on that part which I'm not using)
bbisi
Post by bbisi »
is running with ftp pro. COMMANDER ONE from Mac osx
very good
thank you ALL
Greetings
Bernd
luciodra
Post by luciodra »
What video card did I buy? I tried to put it in the Raven but it shows no signs of life even when changing jumpers. From terminal it gives me "no vga bios detected".
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
LarryL
Post by LarryL »
Looks like a VESA Local Bus Card
https://wikipedia.org/wiki/VESA_Local_Bus
Will not work on a pure ISA bus, I’m afraid…
luciodra
Post by luciodra »
Ahhhhh. :o
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
bbisi
Post by bbisi »
@luciodra
Hi
i want with the raven go to internet. like you shows in this tread
my network is running with sting
ping to the whole sites in my network and ping 8.8.8.8 or 8.8.4.4 and other runs
But I can not see any internet site from cab
like http://www.google.com or other
what did I make wrong
