The resurrection of atari-wiki.com
Re: The resurrection of atari-wiki.com
yes it does. thanks
http://260ste.atari.org
@exxos Wiki isn't work for me right now, have I been banned?
If you are on the same IP address as accessing the wiki as accessing the forum then no you are not banned because you would not be able to post on the forum..Cyprian wrote: Fri Sep 18, 2026 1:39 pm @exxos Wiki isn't work for me right now, have I been banned?
What exactly are you seeing because the wiki loads fine here..
I've just switched from cable network to a mobile network
Dal updated the IP6 DNS yesterday as it had been broken for ages, its not verified it works, but possible your connecting on IP6 whereas IP4 was working before ?
good question, I just checked Wiki from my mobile phone (using different carrier) and it's the same, the site is not available.
From what I can tell IP6 works, but IP4 is broken.Cyprian wrote: Fri Sep 18, 2026 1:50 pm good question, I just checked Wiki from my mobile phone (using different carrier) and it's the same, the site is not available.
Unfortunately I don't own the wiki domain, Dal does, so I sent a message about it..
I will see if I can set up a forum alias for the wiki so is not dependent on the wiki domain name.. Please bear with me while I look into it...
ok, thanksexxos wrote: Fri Sep 18, 2026 1:58 pm From what I can tell IP6 works, but IP4 is broken.
Does this work for you ? https://atari-wiki.com/index.php?title= ... :UserLogin
Works:exxos wrote: Fri Sep 18, 2026 2:44 pmDoes this work for you ? https://atari-wiki.com/index.php?title= ... :UserLogin
Doesn't work:
https://atari-wiki.com/index.php?ti ... :UserLogin
https://atari-wiki.com/index.php?title=Main_Page
