TF1260 New Firmware Alpha Released!
8 Bit Dreams
Re: TF1260 New Firmware Alpha Released!
Post by 8 Bit Dreams »
I'm pretty sure it may be solved by changing CPU. Have seen similar issue on BFG9060 card with rev 1...
Miniworks787
Post by Miniworks787 »
Thanks, I do have an LC cpu I can try.
The rev 1 does work with the alpha firmware at the first power up. It just black screens if I have to power cycle it after it's been on.
Base firmware works fine no matter how many times I power cycle the machine.
Miniworks787 wrote: Wed Mar 01, 2023 10:48 pm Thanks, I do have an LC cpu I can try.
The old "base" firmware as you call it barely taxes the CPU. The "alpha" is now what i consider stable.
Miniworks787
terriblefire wrote: Thu Mar 02, 2023 9:44 am
For some reason my rev 1B board does not seem to play ball when the card is flashed with the alpha. It takes quite a few power cycles to get it past the black screen and do the rainbow flashes and boot with the alpha. When it does get past the black screen and boots it's completely stable. I've never had an issue when using the firmware that came with my card. I suspect it's my 1200 being fussy, but I don't have another one to test with.
I'm happy to stay on the firmware that came with my card as it boots every time. Hopefully I will get an opportunity to try another 1200 at some point.
Thanks
Aardvark82
Post by Aardvark82 »
Are there any plans to release a fix for the cache issue you described on Youtube?
(34:17 mark).
It's glitching out so many games and demos that i had to revert back to the original FW.
Aardvark82 wrote: Tue Mar 07, 2023 10:27 pm
(34:17 mark)
It really only affects the CD32. Its in my queue.
PainDictator
Post by PainDictator »
Finally, After replacing the 32mhz oscillator on my board I can Nö use cpuspeed and Seem to be running fine at 100mhz using the Alpha Firmware.
However, it seems my SysInfo Score is still lower than what everybody else seems to get. While 4,x vs a4000/40 seems to je common, I End Up at 3,7. Any ideas?
Edit: Did some investigation and it turned out, something turned off SUPERSCALAR. So I added CPU SUPERSCALAR and BRANCHCACHE to the startup-sequence. Should be fine for Rev.6 right?
PainDictator
chucky wrote: Fri Dec 17, 2021 8:01 pm (as 8bitbubsy didnt get any activationmail he mailed me)
Message (from 8bitbubsy):
I got the firmware flashed today, using a Rasberry Pi 4 + xcs3prog. Had to disconnect 3.3v from the Pi and power up the Amiga with the board connected.
It seems to run fine, here are my bustest speeds:
Using the alpha fimrware, I keep consistently getting 4,5MB/s maximum (measured at display mode 640x200x2, so no extra DMA in there) at all speeds (50,66,84,94,100). While this is consistent with some posts in the thread, others seem to have almost 7MB/s, which is a huge difference in real life. Any way to get me there?
PainDictator wrote: Mon Mar 20, 2023 11:06 am Using the alpha fimrware, I keep consistently getting 4,5MB/s maximum (measured at display mode 640x200x2, so no extra DMA in there) at all speeds (50,66,84,94,100). While this is consistent with some posts in the thread, others seem to have almost 7MB/s, which is a huge difference in real life. Any way to get me there?
Checking that you're looking at the write performance in PAL mode and absolutely nothing running in the background? Read performance doesnt go as good as 7Mb/s but thats not really important.
PainDictator
terriblefire wrote: Mon Mar 20, 2023 12:04 pm
Ist all the Same here. Of course, write is what I care about.
Any possibility that the RAM cpld is Not properly updated here!
Return to “TF360”
