The new Eprom programmer has arrived.
I went for a GQ-4x4 this time as it got good reviews. It is twice as expensive as the TL866 that I had but is quicker to write 27c4096 chips.
I've written my first eprom with it which was one that the TL866 said was faulty. Its verified correctly etc so looks like the TL866 was definitely dead unfortunately.
Only thing it needs is a nice 3d printed bracket to hold the eprom adaptor board in place.
PhilCs blog / the latest things hes broken(fixed)
Re: PhilCs blog / the latest things hes broken(fixed)
All of this IDE board fun that has been going round has rubbed off on me. For a long time I've wanted to make a Megabus to IDE adaptor. I know I could simply go out and order the same one as @rubber_jonnie has used, the PPera one but I wanted to see if I could elaborate on it a little by fitting buffers and a few other things.
I've also wanted to start getting my own PCB's manufactured. I used to do the old toner transfer stuff but that's a real pain for double sided boards and really messy. So this board will also be an experiment in that but that's not all. the Gal program for a basic IDE board is also pretty basic too, so another quick learning exercise there too.
Then whilst I'm at it, I'm going to make a megabus to 68000 adaptor, to make it easier to plug things like the flashyclock into my mega too.
Or in other words, I've got three weeks away from work and i'm already bored.
Will be very interested to see how you progress with these...still unsure what I can/should do with my Mega4 (but it has a Megafile60 with it already).
Currently only running TOS 1.02 but I have one of exxos' TOS switchers for it (to build) & some 27C4096 EPROMs to program up.
TOS1.04 is a must (I want to use this Mega for some music stuff...it came with CUbase 3.0/Midex+ & a couple of Steinberg synth editor packages)...but I'm wondering which other image to use...
So, something with IDE & TOS 2.06 decoding but that will fit into a Mega is looking attractive...
@JezC I like Tos2.06 myself, so the IDE board will also do the address decoding for that and the likes of emutos 256k images.
I actually prefer the footprint of the Mega and will likely sell off my other STs once I've got the H4's built up and cased for myself. Now if only I could persuade @exxos to make a new Mega motherboard.
@PhilC I'm also a fan of the smaller system unit with the Mega (and it means that the Mega keyboard can fit on top of the synth while sequencing/editing, so I get away with a smaller working area).
Maybe you can take his schematics & fit them into a Mega case after you've successfully created & built your Megabus boards?
I think the idea of a breakout board for the Mega is great - would give us options for fitting all sorts of upgrades...though most would probably not fit inside the height of the original case
@JezC if I did that it might be ready by say 2025
Can't say I'm the quickest at routing PCBs.
@PhilC Well, on that timescale, I might have finished my H4 boards & be able to give you a hand...PhilC wrote: Fri Apr 03, 2020 11:58 am @JezC if I did that it might be ready by say 2025Can't say I'm the quickest at routing PCBs.
@PhilC I prefer the Mega too, and would also like to see a H4 Mega replacement, but I guess it all comes down to numbers. My Mega4 just keeps dying. I fix it, it dies. I fix it agin.... you get the picturePhilC wrote: Fri Apr 03, 2020 11:29 am @JezC I like Tos2.06 myself, so the IDE board will also do the address decoding for that and the likes of emutos 256k images.
I actually prefer the footprint of the Mega and will likely sell off my other STs once I've got the H4's built up and cased for myself. Now if only I could persuade @exxos to make a new Mega motherboard.![]()
Incidentally I am going to patch 1.04 for IDE this weekend, will post how I get along.
@JezC I think we'd probably be better off leaving it in the capable hands of @Icky and @exxos .
Sounds like a plan @rubber_jonnie .
I've finished the routing on the Mega IDE board. I was going to add a rom onto the board but exxos and icky have plenty of good options for me to use for the, so no point at this moment in time.
I do have a whole load of 27c160 & 27c800 but I'll save them for another project, maybe an Amiga one.
Knocked up the quick CPU mega bus adaptor, hopefully it'll work
and done my first JLCPCB order too, lets see how long it takes to get here.
