Looks like I'll be getting a Mega ST4 soon
Re: Looks like I'll be getting a Mega ST4 soon
I would say just go on a "mass resoldering" venture and flux the whole thing up and reflow the whole thing starting with the all the main chips and RAM. I had to resolder half of a STFM a few weeks ago which wouldn't boot up but looked like new. Its sadly how these boards seem to be dying, its like the solder gives up the ghost especially each time you move the thing.
@exxos :cry: :cry: :cry:exxos wrote: 06 Apr 2020 23:32 I would say just go on a "mass resoldering" venture and flux the whole thing up and reflow the whole thing starting with the all the main chips and RAM. I had to resolder half of a STFM a few weeks ago which wouldn't boot up but looked like new. Its sadly how these boards seem to be dying, its like the solder gives up the ghost especially each time you move the thing.
Tomswork
I have to do a mega ste has the same problem lots of work for hot air flux and paste. I'm just short of leaded supplies. The corrosion appears to be in side the board dunouts.
Tom
Tom
@Tomswork the bottom of the board actually seems in better condition than the top of mine with the exception that there are bodge wires and other rework that I've already done. It was extremely grubby when I got it topside and though it's had a damn good clean there is still grime present. The RAM chips all have ground and power, which is great, and given that there is some corruption at the bottom of the screen suggests that perhaps the problem is only related to part of the RAM. Unfortunately the lack of RAM means that though the diag cartridge does try to boot, it doesn't get far enough to do any testing. I will start off by swapping out the 74LS244 chips as that's quick and easy to do, after which I will probably go down the route exxos has suggested, and start reflowing everything in a structured manner. I know this board runs, I've had it running and even stable, it just seems like any physical movement makes it die again, which does play into the possibility that the whole thing has terrible solder joints.
@exxos Just out of curiosity, what is the minimum configuration chip wise that an ST needs to boot? I'm assuming CPU, GLUE, MMU, DMA, MFP, SHIFTER & RAM? I'm theorising that things like the BLITTER, YM, 6850s etc wouldn't prevent it from booting so I can narrow down the areas of investigation. I may test this with the H4, see how little it will actually work with.
You need every chip working.. Maybe not the RTC chip & blitter.. Can't think of anything else.
I know it worked without the YM and Blitter, since they weren't present when it arrived, but it still booted. I'm not looking for full functionality, more reducing the areas I focus on reflowing first before going out to do everything on the board :(exxos wrote: 07 Apr 2020 11:16 You need every chip working.. Maybe not the RTC chip & blitter.. Can't think of anything else.
I just can't help but think it's either the MMU socket or the LS244s. I know the MMU is good, it works just fine in th H4, so thinking I may have a decent spare socket on another donor board.
Well, I needed to keep busy during lockdown :)
Ah yep my chip is sound, parallel,floppy stuff. What I do with suspect sockets is lift one corner up on the chip a tiny bit, normally helps. Or place a couple layers of thin card under it to lift it up a bit.
Edit. I guess the 6850 might not be needed either. Or RS232 or -12 v gen circuit.
Tomswork
@rubber_jonnie can you try the piggy back trick with the ls244
Tom
Tom
@Tomswork In all honesty I don't know if that will work, but the thought had crossed my mind.Tomswork wrote: 07 Apr 2020 20:05 @rubber_jonnie can you try the piggy back trick with the ls244
Tom
It's actually just as easy to desolder with my gun, it takes no time at all and will give me an opportunity to install sockets anyway. Plus once they're out I can test them with my TL866 anyway.
I may try it, will post here anyway with progress.
Hi all, so I managed to get some decent diagnostics from the Mega4 thanks to the diag cart and the serial cable.
Here's what I'm seeing:
If anybody has any experience with interpreting this I'd be very grateful :)
Looking at the data in/out lines on all the RAM chips, out is the same , but 2 chips are showing differences on the data in lines, so it could be those that are dead, but I'd like to try and map the image above into something physical, clearly it is some sort of RAM issue.
Users browsing this forum: ClaudeBot, GoldenGraham and 19 guests
