SpeedyTT, black screen of death !!!! HELP
Re: SpeedyTT, black screen of death !!!! HELP
I agree with @Steve regarding fractured tracks or vias too.
I've had 2 instances, a Mega ST and an Amiga 500 where manual handling of the board damaged tracks/vias invisibly causing dead machines. I managed to track down and fix the issues but I do always warn people that working on these old boards is a risk, the manual handling of them could cause unseen damage, especially if the board gets flexed at all.
I'd suggest that you need to start troubleshooting the base machine with a minimal config.
zfrenchy
Post by zfrenchy »
I found something !
This is the MCU, shorted pin 81(SINT) and 82(SZ1)
But still dead black screen.
I am asking the expert, by having these two pin shorted, what part might be dead ?
both pin connected with the short to:
UA00 (DMAC chip): pin 7
U907: 74LS86 pin 10
J502 (memory connector): pin 77
JB01 (TT RAM): pin 48
HigashiJun
Post by HigashiJun »
I would advise to remove the solder blob first and then check if your TT is still alive.
HigashiJun wrote: 06 Jan 2026 05:39 I would advise to remove the solder blob first and then check if your TT is still alive.
I'd agree 100%, that solder blob shouldn't be there. Get it removed.
zfrenchy
Post by zfrenchy »
Of course I removed it ! :D
Still black screen :(
HigashiJun
So check the continuity on all the 6 sockets you have fitted in order to install the Speedy.
There must be somtehing wrong somewhere (provided you didn't fry a component).
zfrenchy
Post by zfrenchy »
Yep, find where these 68 points are going to be tested !
HigashiJun
Good.
zfrenchy
Post by zfrenchy »
Little parenthesis in my process, here is a searchable TT schematic PDF I made for facilitating the following of wire without turning pages.
https://drive.google.com/file/d/12k8qL4 ... sp=sharing
zfrenchy wrote: 07 Jan 2026 03:44 Little parenthesis in my process, here is a searchable TT schematic PDF I made for facilitating the following of wire without turning pages.
This is a great resource! Thanks for sharing
Users browsing this forum: Amazon [bot], Bing [Bot], ClaudeBot and 7 guests
