STE without Blitter chip?
Reluctant16bitter
Re: STE without Blitter chip?
Post by Reluctant16bitter »
So if I put in a C101643 and cut the wired and it doesn't work, can it damage my Atari STE, or can I just try it to see if it works?
Atari 1040STE (4 MB RAM) | Sinclair ZX Spectrum +2A | Sony HB-F1XV MSX2+ (512 KB RAM, 7MHz Z80, WozBlaster OPL4, PowerGraph Light V9990) | Philips VG8235 MSX2 (1 MB RAM, 7MHz Z80) | Mitsubishi ML-FX1 MSX
dml
Post by dml »
Reluctant16bitter wrote: Sat Aug 30, 2025 10:13 am So if I put in a C101643 and cut the wired and it doesn't work, can it damage my Atari STE, or can I just try it to see if it works?
Putting a genuine blitter IC in the STE board won't damage the STE, even if it doesn't work. As for cutting/soldering wires etc... that's always another matter. It is not a mod I'm familiar with so you'll need to rely on your own research and advice from the others above.
Putting a fake/re-marked IC in the board is a different question though. Low chance of causing any damage but not impossible. You'll need to decide for yourself if you're confident it's a real part from a trustworthy source and take the (probably low) risk of trying it in the board.
Reluctant16bitter wrote: Sat Aug 30, 2025 8:46 am Sorry for asking again, but I'm quite new to Atari computers. So I found a C101643 on eBay and https://www.best-electronics-ca.com/custom-i.htm seems to confirm this is an STE blitter. Am I right?
If you look at the STE motherboard picture I linked to earlier in the thread, it has a C101643 blitter installed, so I'd suggest it'll be fine.
chronicthehedgehog
Post by chronicthehedgehog »
My STE also has a C101643-011 installed.
Previously it had a MM9092V - which worked fine - I just swapped it out due to an early MonSTErbo incompatibility (now fixed)
Reluctant16bitter
rubber_jonnie wrote: Sat Aug 30, 2025 11:12 am If you look at the STE motherboard picture I linked to earlier in the thread, it has a C101643 blitter installed, so I'd suggest it'll be fine.
It's a bit hard to read, but yes, thanks!
chronicthehedgehog wrote: Sat Aug 30, 2025 12:54 pm My STE also has a C101643-011 installed.
Thanks for confirming!
Reluctant16bitter
Expecting delivery of my Blitter today. Seeing as some on this forum damaged socket pins, what is the best way to place it? Any tips or other things I should take into account?
Also, it is square. How will I know which way to point which side?
dml
Post by dml »
Reluctant16bitter wrote: Thu Sep 04, 2025 12:49 pm Also, it is square. How will I know which way to point which side?
PLCCs usually have one chamfered corner on the edge with pin #1 - and also a dot/dent in the chamfered edge exactly at pin #1.
The dot might be at the corner on some ICs but they all have the chamfered corner and the socket has it too so you should be able to tell which way it goes if you look carefully. If in doubt, photo both and post here :)
Reluctant16bitter
On close inspection, I could see the chamfered corners, both in the socket and on the chip, but I saw something on the chip that doesn't look good:
Will that be a problem? And can I repair that?
Reluctant16bitter
Reluctant16bitter wrote: Thu Sep 04, 2025 2:10 pmWill that be a problem? And can I repair that?
Apparently, it probably was, but, using a pair of tweezers, I could:
I appear to have a blitter now!
:girldance:
The pins often get like that when not removed carefully, but as you've found are able to be adjusted quite easily. For reference one corner is notched differently to key it and there is usually a dot in the middle of one side that indicates pin 1, and the silkscreen usually shows pin 1 as well.
Glad to see it working, and I'd suggest that you reinstall the clamp :)
