Apples aren't the only fruit.
Re: Apples aren't the only fruit.
PVA seems to glue properly.
However, it's not as good as first thought.
After redoing five keys two don't work, so the bags are probably not evenly conductive.
Ordered some metalised emergency blankets...
Would contact adhesive be better? I Wouldn't have thought PVA would work well with plastic etc.
rubber_jonnie wrote: Tue Feb 27, 2024 9:51 pm Would contact adhesive be better? I Wouldn't have thought PVA would work well with plastic etc.
Contact adhesive may melt the plastic foam.
stephen_usher wrote: Tue Feb 27, 2024 10:01 pm
Ahh, good point.
Just realised I had this:
Might be something to consider, it's metal tape with adhesive on one side, came with my PGA reballing machine for using to isolate components from heat.
That tape is quite a low resistance. We use it at work for boiler lagging.
What about conductive painting the surfaces?
I bought some mylar emergency blankets and tried making some pads tonight.
As long as you make sure that the metalised surface is AWAY from the PCB, i.e. on the foam side, they work well. The metalised side is very conductive so it causes a short.
The foil coated foam isn't great, so next stuff to try... weather proofing strip. You can get it as 12mm wide and 3mm thick strips with adhesive on both sides. Stick the mylar to one side and the plastic disc on the other. Well, that's my plan. It's also cheap.
PhilC wrote: Wed Feb 28, 2024 7:23 pm That tape is quite a low resistance. We use it at work for boiler lagging.
The issue is that the keyboard uses capacitance rather than conductance. If you try foil (which I did at first) things go haywire as it bridges the traces and causes a short.
stephen_usher wrote: Wed Feb 28, 2024 8:04 pm
Ok that makes sense. Good luck with trying to replicate that, I’ll be very interested to hear how you manage it
