MegaST ROM adapter - black screen
Upgrade or replace the ROM.
Re: MegaST ROM adapter - black screen
Badwolf wrote: Tue Jan 30, 2024 1:41 pm
HigashiJun wrote: Mon Jan 29, 2024 9:44 am Oh, and BTW, may we know which TOS version you're trying to run ?
If you want TOS 2.06, then you also need a TOS decoder to make it work.
There are four chips.
Two have TOS1.04UK/EmuTOSUK 192k in them. One has EmuTOSPL and Tos1.04UK in it.
These three chips have been tested in my STFM.
The last chip has TOS2.06 and EmuTOS256 in it. I've suggested to Arti changing the chip in case he's randomly picked the TOS2.06 version by accident (none are labelled, I figured it'd be obvious). I've also suggested trying the chips in his STFM, which is known to work. Not heard back.
Thanks BW :)
HigashiJun
Post by HigashiJun »
Thank you @Badwolf.
arti040
Post by arti040 »
HigashiJun
Is the yellow capacitor soldered on one side only ?
HigashiJun
@Badwolf
When did you burn the EPROM for @arti040 ?
arti040
Post by arti040 »
HigashiJun wrote: Fri Feb 02, 2024 11:43 am Is the yellow capacitor soldered on one side only ?
Yup. As in the documentation.
It's only a decoupling cap but that's the point of it being there if it's only connected on one side?
It shouldn't make any real difference but it should be soldered each end.
arti040
Post by arti040 »
Ouch, I misunderstood the question. Of course, it is soldered from both sides! :-)
OK, so looking at the bottom I can see two solder joints that don't look right, shown by the arrows:
The top one looks like it has bridged across to ground, and the bottom looks like it is a cold or incomplete joint.
I'd still suggest that you need to change the jumper header to a square pin type as those round pins won't make good contact through that jumper, they are too small.
HigashiJun wrote: Fri Feb 02, 2024 11:45 am @Badwolf
Start of January. It's not EPROM bitrot. I'm still using uncovered EPROMS from two years ago.
What I would suggest is putting the EPROM in the dualtos-equipped STFM I know Arti has to check the ROM is working and is the right one!
Return to “ROM UPGRADES”
