OSI 600D Superboard Build
Re: OSI 600D Superboard Build
HigashiJun wrote: Sun Jan 07, 2024 10:57 pm
rubber_jonnie wrote: Sun Jan 07, 2024 5:03 pm It is indeed :)
I got some more done today:
However there are some component oddities around resistors and capacitors I need to clear up from the assembly guide, and there are parts I don't yet have, but yeah, it is starting to take shape and I'm pretty pleased.
I decided to fit just the one keyswitch as a trial, and I'm quite pleased , it's a great fit.
Can't wait to see the final result !
:D
Me either :)
May be a couple of weeks though, depends when the remaining parts arrive.
HigashiJun wrote: Sun Jan 07, 2024 10:56 pm
rubber_jonnie wrote: Sun Jan 07, 2024 4:59 pm I'm undecided at this point, as I don't have the facilities/tools to easily make a case, but I may consider doing so at some point.
Such a pity that a case kit doesn't exist...
Just to add, I've been looking around over on OSIWeb and it seems the commercial version of the OSI were called the Challenger and came in a case. Sadly no sign of the plans!!
The keyboard matches this:
Screenshot 2024-01-07 at 23.44.53.png (1.31 MiB) Viewed 11145 times
And if I were to build a case, it would be very much along these lines, though I'd likely make the entire thing from plywood since I just don't have the facilities/tools to bend a metal plate like that, though I do have the skills having worked in a sheet metal shop for some time.
HigashiJun
Post by HigashiJun »
@rubber_jonnie
I've found this:
https://www.vintagevibe.co.nz/vintage-c ... oard-revd/
The guy made his own OSI case, but without the appropriate tools and knowledge, it would be a challenge...
Plywood is traditional.
Looks a lot like the Nascom 1s we had at school.
HigashiJun wrote: Mon Jan 08, 2024 1:27 am @rubber_jonnie
I've found this:
Nice, that's spot on.
stephen_usher wrote: Mon Jan 08, 2024 6:53 am Plywood is traditional.
Indeed, and having watched a lot of similar machines on Tech Time Travellers YT channel this was the way these machines looked back in the day.
I never saw a Nascom when I was younger, but very aware of them and there are definite similarities.
HigashiJun
@rubber_jonnie @stephen_usher
You can even build something like this:
Apple I.jpg (58.9 KiB) Viewed 11112 times
(And become famous and rich later...)
:lol:
HigashiJun wrote: Mon Jan 08, 2024 9:47 am @rubber_jonnie @stephen_usher
:lol:
I'd hope for something a little less ramshackle :)
HigashiJun
rubber_jonnie wrote: Mon Jan 08, 2024 10:09 am I'd hope for something a little less ramshackle :)
Yes, that would be more reasonable...
HigashiJun wrote: Mon Jan 08, 2024 10:39 am
I think once it's built and working, I'll give it a go, but I'll need to sort out my workbench first, it needs a new top, then some extra tools to help me shape it. It'll be a while off, but definitely worth the effort.
Return to “8 BIT CORNER”
