I did specify the wiki database. It dumped the lot anyway.elterwater wrote: Sun Dec 24, 2023 9:40 pm As per the manual, you need to specify the DB name of the wiki you want to be dumping out otherwise you'll get everything including MySQL server users....
Today's server problems
Re: Today's server problems
not with the command you showed above
mysqldump -u root -p redacted > wiki7b.sql
And remember: Beethoven wrote his first symphony in C.
Install trafik/prometheus/grafana and keep some dashboards showing you your server stats/health. Most people overpay a lot for servers.
I run a home server with 4 cores, SSD and 32GB RAM. It's not even at half load and it's running _lots_ more than you are from what I can see :/
