Tidying up a Falcon & CT60 combo (power supply & drive)
PacificState
Re: Tidying up a Falcon & CT60 combo (power supply & drive)
Post by PacificState »
FWIW, it does feel like a dry joint somewhere, given that the RAM issue is so intermittent.
PacificState
Hmm - so I was reflowing the CPLDs, and noticed something odd. While there's a bit of minor (existing) damage to the middle pins on one side (visible at the top left of the picture - they're still connected, though), there appears to be a piece of something (metal?) under one of the pins (fifth from the bottom right). I don't think it's a lifted pad - can anyone tell me if this is the same as on their CT60?
PacificState
And... it's the pad underneath - maybe this was reworked before, as I didn't apply excessive heat? I guess I'll try to bridge it to the track.
coonsgm
Post by coonsgm »
Thank you so much for posting this!! I have experienced a similar set of symptoms as you were describing on my CT63 since I bought it new about a year and a half ago.
I could never get it to recognize fast ram and while it would work kind-of, I ended up switching to a DFB1. I tried have 5 different pico-psu's, a dozen sticks of specifically sourced PC133 RAM and 3 68060 CPU's (only one is a full fat one with FPU thank goodness) and had really given up on it.
I JUST reflowed the CPLD pins thoroughly (I had tried it half heartedly in the past) and BOOM the fast ram is recognized and it's working like I think it was supposed to from the beginning! I ran the CT63 diagnostic and all the RAM passed!!
Thank you thank you thank you!
PacificState
I'm glad it helped! In my case, reflowing the two CPLDs seems to have fixed the RAM recognition - but I'm still getting the 'not a Falcon 030' error on boot intermittently, and the temperature monitor isn't still not read. Anything else I can try?
PacificState
OK - I left this aside for family stuff for a little while, and now I'm back on it and tearing my hair out. Since the last post:
- I ended up buying a new CT63 from Centuriontech as the original CT60 stopped recognizing RAM (so I thought this could be another sign the accelerator was at fault)
- It's installed OK with a *different* rev 6 68060 which was tested in an Amiga
However, although the ram problem is now fixed, the machine *still* fails on first boot - it used to boot to the 'this machine is not a Falcon 030' dialog, whereas after booting to a freshly erased drive, it now boots to a 2 colour (red and white) display - presumably due to the same problem. If I then soft-reset, everything works perfectly until I turn the machine off.
Notes:
- Booting at 33Mhz (half the 66Mhz default) doesn't help
- I cannot run any programs in this state as they hang - running SysInfo, for example, to read the cookie jar as suggested earlier in the thread, hangs up the Falcon with a busy icon. Similarly, whilst I can open the TOS panel to change the screen resolution (which informs me that the display is set to 2 colors), that hangs too if I (say) change to 256 colors and click OK.
- I've tried replacing both the SODIMM on the CT63 and the ST (14MB) memory - the latter takes a SIMM, which I've swapped out
- The CT60 boot menu offers an option to drop to diagnostics - all seem to pass
From the earlier suggestions, it sounds like the likely cause here is a corrupt cookie jar - it's therefore a bit unfortunate that I can't run anything to introspect it. It's odd, too, that the machine otherwise runs fine. Are there any suggestions as to what I could look at further? Thanks!
PacificState
Sorry to reference another forum, but I'm pretty sure that this is the same problem called out at https://www.atari-forum.com/viewtopic.p ... 30#p402830. Does everyone basically reset and get on with things?
If pressing reset fixes the problem then you likely need to change the reset caps on the falcon.
Also may or may not be relevant https://www.exxosforum.co.uk/forum/view ... 00#p110236 Pavel apparently used to thin PCB traces on the ATX connector causing all sorts of problems. So it might be misleading that you you have tried 2 CT60s and still have problems. I had nothing but problems with my original CT60.https://exxosforum.co.uk/atari/last/CT60/index.htm including some brands of osc causing problems as already mentioned.
PacificState
That's really interesting. I should mention two more things:
- I did just swap out the caps in the reset circuit, with a 47uF @ C1 and 22uF at C7 (new Cornell Dubilier caps from Digikey)
- Separately, I do have a reset problem that I didn't seem to have a with the original CT60, in that it can take a few tries to start up. Recapping didn't help, and I'm using what I think is a good quality PicoPSU from Mini Box (https://www.mini-box.com/PicoPSU-120).
I definitely wonder if this is one problem or several:
- Not consistently starting. There seems to be a history of this for other people, who fix it with new reset caps, decoupling caps (https://www.atari-forum.com/viewtopic.php?t=23218), or even additions to the reset circuit (as in the thread you posted)
- Not initializing as a Falcon at boot (although this was happening with the old CT60 before I changed the reset caps). From what I can tell on other threads, this *seems* ultimately to be related to the SODIMM RAM test running - so maybe that's wiping out the cookie jar?
Otherwise, thanks for pointing to that thread - I'll look at the 5V voltage today...
I haven't read the whole thread. But I assume you know there's issues with some ram...https://exxosforum.co.uk/atari/mirror/p ... sdram.html
