Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
Re: Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
I have replaced my sd card adapter, which had a 5v to 3.3v reg plus transceiver chip, with a 3.3v part. Now attaining 1.15 MB/s with the SPI clock at 37MHz. The sd cards I have will run at 41MHz, but not 50MHz. So I will play with clocks to gain a little more performance
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Frankly, that performance is exceptional already, in my book.dad664npc wrote: Fri Nov 04, 2022 3:59 pm I have replaced my sd card adapter, which had a 5v to 3.3v reg plus transceiver chip, with a 3.3v part. Now attaining 1.15 MB/s with the SPI clock at 37MHz. The sd cards I have will run at 41MHz, but not 50MHz. So I will play with clocks to gain a little more performance
I think the Falcon's IDE is only about 1MB/s.
Are there many people who moan about ASCI speeds when the alternative is floppy?
Depends on a disk driver and the disk itself ( cf, SD or plates one). My best result was 3.2MB/s with Hushi IIRC.
And the CPU accelerator can significantly improve IDE performace.
Atari V4sa / Lynx I / Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM146 / SM124 / SC1435
Antonia 2 / ATW800/2 / SidecarTridge / ACSI2STM / Mach64 VME / Mach32 VME / ET4000 VME / Atari 1050 / DDD HDD / AT Speed C16 / TF536 / SDrive / PAK68/3 / Lynx Multi Card / XCA12 / SkunkBoard / CosmosEx / SatanDisk / UltraSatan / USB Floppy Drive Emulator / Eiffel / SIO2PC / Crazy Dots / PAM Net
http://260ste.atari.org
Two SD cards now work and can perform a copy disk between the two via the integrated shell command 'cpdisk'
GitHub updated
GitHub updated
First PCBs expected tomorrow
I agree with BW, that was exceptional speed. I think most other ACSI emulators max out at around 950k/s!dad664npc wrote: Fri Nov 04, 2022 3:59 pm I have replaced my sd card adapter, which had a 5v to 3.3v reg plus transceiver chip, with a 3.3v part. Now attaining 1.15 MB/s with the SPI clock at 37MHz. The sd cards I have will run at 41MHz, but not 50MHz. So I will play with clocks to gain a little more performance
Following from afar, great work !
jfceklosky
The board looks great I would like to my hands on one to test out!
jfceklosky
I see the github repo for the board schematics above which is great.
Can the gerbers for the board shown above be released? I would like to have some printed and built to test with.
Thanks!
Thanks!
