QL vDrive upgrade
Re: QL vDrive upgrade
@stephen_usher Just wondering if you have any experience of mdump_task for the QL?
I have managed to get this onto floppy and run the command: ew flp1_mdump_task as instructed here: http://qxl.win/ql_cartridge_recovery.htm
However all I get in return is 'bad parameter' suggesting I need to perhaps add something extra to the command line. It's driving me nuts as I want to test mdv cart dumping, but it just won't run :(
All thought welcome, and I will also have a look over on the QL forum.
I've forgotten what the program was I used to read the carts. It was by an Italian bloke. I wish I could remember.
stephen_usher wrote: Thu Nov 11, 2021 10:03 pm I've forgotten what the program was I used to read the carts. It was by an Italian bloke. I wish I could remember.
If it's the Italian bloke I'm thinking of it's mdump_task, which I can find precious little info on how to run. I've got a post up now on the QL forum, so we'll see if they can give me any pointers.
rubber_jonnie wrote: Thu Nov 11, 2021 10:11 pm
It's Simone Voltolini, website here: https://sinclairql.wordpress.com/
You may have seen my posts here by now: https://qlforum.co.uk/viewtopic.php?f=1 ... 8&start=10 but I managed to create a disk from an image that contained the beta 2.0 version of mdump_task and can now boot from floppy to run it, and have copied 3 carts. I now need to fix the pads in the carts I really want to back up and then understand how I can convert the images for use with vDrive.
I have a newer version of mdump now too, so need to unzip that in QDOS and add it to my boot disk.
:dualthumbup:
stephen_usher wrote: Fri Nov 12, 2021 2:14 pm :dualthumbup:
Just to add, I also bought Q-Emulator :)
That should help
I've used SMSQmulator ( https://www.wlenerz.com/SMSQmulator/ ) in the past to do the disk transfer. It can also handle Microdrive images from what I can remember.
stephen_usher wrote: Fri Nov 12, 2021 4:12 pm I've used SMSQmulator ( https://www.wlenerz.com/SMSQmulator/ ) in the past to do the disk transfer. It can also handle Microdrive images from what I can remember.
That was suggested too over at the QL forum, just not had a chance to play with it today.
@stephen_usher
So I splashed out on Q-Emulator and it really did make life easier. I have been able to make a boot floppy for mdump_task and was able to do some cartridge dumping earlier :)
I managed to dump all of my MICE carts, so ICICLE, TOOLKIT, SPRITEGEN and MICEART plus my Talent Assembler Toolkit and port them back to vDrive QL and use them as MDV images, so altogether a successful day.
To top it off I managed to get the felt pad replacement technique sorted for the carts I was trying to preserve :)
Return to “OTHER 680x0”
