TF1260 New Firmware Alpha Released!
PaulJ_2.0
Re: TF1260 New Firmware Alpha Released!
Post by PaulJ_2.0 »
supaduper wrote: Fri Dec 17, 2021 8:31 pm You can send back to me to test that way we can eliminate either the Card or your A1200
It's fine, I can troubleshoot the issue have spare cplds and ram.
It's probably not the card as I have had issues with firmware revisions on the TF1230 too on this 2B.
I will plug away, but thanks for the offer.
trixster
Post by trixster »
Looking forward to trying this tomorrow!
8bitbubsy
Post by 8bitbubsy »
Ok, finally got my account activated. Just wanted to say that the new alpha FW works fine on my TF1260. Good job! :)
GadgetUK164
Post by GadgetUK164 »
PaulJ_2.0 wrote: Fri Dec 17, 2021 8:18 pm
supaduper wrote: Fri Dec 17, 2021 8:09 pm With no boot device on the A1200 does it go to the insert floppy rom screen ?
PaulJ_2.0 wrote: Fri Dec 17, 2021 7:46 pm LED power stays dim.
It doesn't even start to initialise.
Even Diagrom wont start.
Make sure your PCB edge is super clean - I found I had to clean mine every single time I updated the fw, maybe its due to higher current pulled by this card? Also, disconnect and reconnect your power connector then try again. Also check you are using the correct .jed for the ram. If you have the 6nS one use that, but if its like mine you will probably have the 10nS chip.
GadgetUK164
Enjoying the silence...
Danoo
Post by Danoo »
Thanks for the early Christmas gift @terriblefire, will give it a whirl in the next few days, tis the silly season and the brain is a little fuzzy ATM :lol:
Life is really simple, but we insist on making it complicated - Confucius
Aardvark82
Post by Aardvark82 »
Some interesting results with full rev6 cpu, 1D4, KS3.1.4, Mediator tower:
50Mhz-66.667Mhz fine
75Mhz crash reboot
78Mhz-82.5Mhz instant freeze
93.75Mhz causes graphical corruption, freezes after doing cpuspeed again.
100Mhz completely stable
trixster
Post by trixster »
Superb work Mr TerribleFire!
trixster
Post by trixster »
And the all important AmiQuake Timedemo demo1 score is 17.3fps.
The fastest I ever saw for a Blizzard 1260 80mhz is 16.3fps, so TF1260 takes the crown easily!
I dont think its possible to make a real amiga using original CPU go faster than this without a cryo cooler. I'll fix 75Mhz in time and work on some stability things.
Return to “TF360”
