zChrises 520 STfm + TF536 project.
zChris
Re: zChrises 520 STfm + TF536 project.
Post by zChris »
Technoid6502 wrote: Sat Apr 03, 2021 11:04 pm As for programming the TF536, I used a Xylinx platform device with the Xylinx ISE 14.7 under WIndows 7 (in a virtual machine under Linux). If you use other versions of the Xilinx software, the machine will report that nothing is on the chain. So, best guess, is that you are not running v14.7.
Best,
Jeff
Hello Jeff,
What cable did you use? I tried to talk with it with a Raspberry Pi 2 Model B.
/zChris
zChris
Post by zChris »
Alright some update.
I have gotten exxos PSU but there doesnt seem to be any improvement.
Are there any caps on the motherboard that needs to be replaced ?
Best regards zChris
Technoid6502
Post by Technoid6502 »
zChris wrote: Mon Apr 19, 2021 1:17 pm Hello Jeff,
This is the cable I used, but I bought mine on ebay in 2019 for about half what amazon is charging. Use the ISE 14.7 software with it and you'll get traction. Later versions of the software see the device, but won't do anything with it.
zChris
Post by zChris »
Hello,
Ive been able to got ahold of DiagROM's. When i use the roms with regular CPU it comes to the menu and i can do a memory test. But when i try with TF536 it looks like this: https://photos.app.goo.gl/s9XTcdU1v9tfoJ1q9
After it got stuck at the darkgreen image i pressed the reset button. And thats when it flashes.
best regards zChris
zChris
Post by zChris »
Hello,
I have measured A0(Pin29) and A4(Pin32) on the CPU with a logic analyser.
A0 With regular CPU:
A4 With regular CPU:
A0 with TF536:
A4 with TF536:
I think this can be a problem?
I am slightly confused what you are measuring because the 68000 doesn't have A0....
Just watched the video, the flashing is right, I'm wondering if you connect a serial cable to your ST if you get an output on the serial port as it certainly looks like it's booting Diagrom but there is an error with something on the ST.
Do you want to send the ST and TF536 to me to take a look at it @zChris ?
zChris
Post by zChris »
exxos wrote: Thu Apr 22, 2021 9:48 pm I am slightly confused what you are measuring because the 68000 doesn't have A0....
Im sorry exxos its A1 that im measing (pin 29)
zChris wrote: Thu Apr 22, 2021 10:13 pm Im sorry exxos its A1 that im measing (pin 29)
Have to measured on resistance to see if that pin has like 10K pull up to 5V ? It looks like it is not being driven active high properly.. It could just be one of those things where you need to do the mandatory fixes to solve such problems..
zChris
Post by zChris »
exxos wrote: Thu Apr 22, 2021 10:16 pm
Dont follow your first senctence but i have done the mandatory changes that is not related to discdrive. Like changen the netresistors to 10K. Also had that resistor fix on C68 thing.
